[idea] Garage parking assistance
Simplify IoT Development.
User avatar
uwe.fetzer
Contact:
Post by uwe.fetzer » Thu Apr 28, 2016 2:47 am
Used Grove Moduls :
- Ultrasonic Ranger
- Speaker
- LED Strip
and Raspberry Pi as Wio Server
Python Script:
Code: Select all
import requests
import time
if __name__ == '__main__':
    url_range = 'http://192.168.38.58:8080/v1/node/GroveUltraRangerD1/range_in_cm?access_token=9164e46e6c460b57b711ac90eca626b9'
    response = requests.get(url_range)
    range_cm = response.json()['range_cm']
    leds = int(0)
    while range_cm > 5 :
        leds_old = leds
        leds = int(range_cm / 10)
        if leds > 20 :
            leds = 20
        if leds <> leds_old :
            rgb = ''
            rgbs = int(0)
            while rgbs < 20 :
                rgbs += 1
                if rgbs <= leds :
                    if leds < 5 :
                        rgb += '110000'
                    else :
                        rgb += '001100'
                else :
                    rgb += '000000'
            url_leds = 'http://192.168.38.58:8080/v1/node/GroveLedWs2812D0/segment/0/' + rgb + '?access_token=9164e46e6c460b57b711ac90eca626b9'
            requests.post(url_leds)
        print(range_cm, leds)
        if leds < 2 :
            url_beep = 'http://192.168.38.58:8080/v1/node/GroveSpeakerD2/sound_ms/1000/200?access_token=9164e46e6c460b57b711ac90eca626b9'
            requests.post(url_beep)
        elif leds < 3 :
            url_beep = 'http://192.168.38.58:8080/v1/node/GroveSpeakerD2/sound_ms/800/200?access_token=9164e46e6c460b57b711ac90eca626b9'
        elif leds < 4 :
            url_beep = 'http://192.168.38.58:8080/v1/node/GroveSpeakerD2/sound_ms/600/200?access_token=9164e46e6c460b57b711ac90eca626b9'
        elif leds < 5 :
            url_beep = 'http://192.168.38.58:8080/v1/node/GroveSpeakerD2/sound_ms/400/200?access_token=9164e46e6c460b57b711ac90eca626b9'
        time.sleep(.5)
    url_leds = 'http://192.168.38.58:8080/v1/node/GroveLedWs2812D0/clear/35/000000?access_token=9164e46e6c460b57b711ac90eca626b9'
    print("End")
Video:
philip.mallon
Contact:
Re: [idea] Garage parking assistance
Post by philip.mallon » Thu Apr 28, 2016 3:13 pm
This is a great idea and well done. We have one that uses laser guidance for the driver in the garage and it senses the car by heat. On a cold day it does not work so we may try your construction. We think it is one of the best gadgets in the house. Is the range of the ultrasonic sensor too short?
teng.wang
Post by teng.wang » Thu Apr 28, 2016 5:56 pm
I love it. Good job.
User avatar
uwe.fetzer
Contact:
Post by uwe.fetzer » Thu Apr 28, 2016 6:09 pm
Hi Philip,
I've set the range to a such low value just to test the solution in my office.
You can adjust the value in the code:
Code: Select all
