App crash when select a node
Simplify IoT Development.
calvin2
Post by calvin2 » Fri Apr 15, 2016 12:19 pm
After configuring the wio link board, I can see there is 1 node in my Android App.
Clicks on it and the app crashes. See the screen cap below. (replace [dot] with . because I can't post link...)
imgur[dot]com/YuCF23t
imgur[dot]com/xALTgEt
calvin2
Re: App crash when select a node
Post by calvin2 » Fri Apr 15, 2016 12:30 pm
Clicks on Api or Setting cause app crash too.
Tried my 2nd wio link board. Also same. :cry:
yexiaobo
Post by yexiaobo » Fri Apr 15, 2016 3:45 pm
Could your log more info about your phone and OS version?
And, pls update Wio Link app to 2.2.0.
calvin2
Post by calvin2 » Fri Apr 15, 2016 4:16 pm
Yes I am already using 2.2.0 (Latest from play store)
I am using a Note 4, android 5.1.
It happens when I tap on any nodes on the screen. (I have 2 nodes)
The stack trace is pointing to:
IndexOutOfBoundsException Invalid index 0, size is 0.
at cc.seeed.iot.ui_setnode.SetupIotlinkActivity.java:123
peter.lans
Post by peter.lans » Sat Apr 16, 2016 9:08 pm
I had the same problem on a Nexus 5 with Android 6.0.1.
After deleting and reinstalling the app, the problem is solved for me.
I hope this will help you.
calvin2
Post by calvin2 » Sat Apr 16, 2016 10:14 pm
It seems like previously the app does not get a list of groves. (For unknown reason..)
After uninstall and install, it can get the list and hence the app does not crashes anymore.
Thanks! :D
