How many Grove does Wio Link support
By now.
Grove list which supported by Wio Link:
sku_101020008 Grove - Moisture Sensor
sku_101020078 Grove - Air quality sensor v1.3
sku_103020005 Grove - Relay
sku_103020012 Grove - SPDT Relay(30A)
sku_103020014 Grove - Dry-Reed Relay
sku_103020004 Grove - Solid State Relay
sku_101020003 Grove - Button
sku_111020000 Grove - Button§
sku_101020030 Grove - Digital Light Sensor
sku_101020038 Grove - Magnetic Switch
sku_101020072 Grove - Barometer Sensor(BMP180)
sku_101020088 Grove - Multichannel Gas Sensor
sku_107020001 Grove - Speaker
sku_105020005 Grove - EL Driver
sku_101020048 Grove - Rotary Angle Sensor§
sku_101020017 Grove - Rotary Angle Sensor
sku_101020083 Grove - Gesture
sku_101020039 Grove - 3-Axis Digital Accelerometer(±1.5g)
sku_101020034 Grove - 3-Axis Digital Compass
sku_101020050 Grove - 3-Axis Digital Gyro
sku_101020011 Grove - Temp&Humi Sensor
sku_101020019 Grove - Temperature&Humidity Sensor Pro
sku_316010005 Grove - Servo
sku_101020040 Grove - IR Distance Interrupter
sku_104990202 Grove - WS2812 RGB LED
sku_104020006 Grove LED Bar v2.0
sku_104030008 Grove - OLED Display 1.12’’
sku_101020020 Grove - PIR Motion Sensor
sku_101020015 Grove - Temperature Sensor
sku_101020073 Grove - Electromagnet
sku_105020001 Grove - I2C Motor Driver
sku_101020035 Grove - Protoshield
sku_103020006 Grove - I2C Hub
sku_104030003 Grove - 4-Digit Display
sku_101020026 Grove - Infrared Emitter
sku_101020016 Grove - Infrared Receiver
sku_111020001 Grove - Encoder
Thanks xieliang,
You can find What Grove modules is suppported in your APP, but it’s not comprehensive.
For example:
  1. There’re still some switch signal controlled modules aren’t list in the APP such as Grove - Water Atomization. High level signal can make it start working, Low level signal can stop working just link Grove Relay Module.
  2. And there’re also some analog output modules maybe not list in the APP, such as Grove - PH Sensor. But you can still use it using the analog input port of the Wio Link, then translate the analog values into physical data in your code.
For advanced users, they can write the module driver by themselves, for more info about how to write module driver for Wio Link, please put hand on https://github.com/Seeed-Studio/Wio_Link/wiki/How-to-write-module-driver-for-Wio-Link%3F
