WIO Link not connecting to Android
Simplify IoT Development.
luwii.vanderwalt
Post by luwii.vanderwalt » Tue Mar 29, 2016 8:51 pm
Received my WIO link today, super excited, but got stuck quite early on.
Using the App V2.1.2 on Andriod V5.0.1 on a Galaxy S4.
After pressing the Config button for 4 seconds, the blue light stops flashing, pressed the 'Got Ready' button and the app should list the WIO to connect to. But nothing happens. Pulling up and down seems to trigger a refresh, but still nothing appears.
I can see the WIO in list of Wifi networks on the phone (if you held down the config button on the WIO). I tried connecting to the WiFi first, as well as during the time I was running the app. The phone connects, WIO gives me an IP, but then I get a 'connect server failure' message in the App when I press the 'Got Ready' button.
Rebooted the phone, 'forgot' the WIO network settings.. Nothing seems to help, ran out of ideas to try .... any suggestions?
luwii.vanderwalt
Re: WIO Link not connecting to Android
Post by luwii.vanderwalt » Tue Mar 29, 2016 9:50 pm
Update
Found the 'Advanced user Guide' in Github, tried the instructions under 'Bricked WIO Link' in case the firmware was out of date. The instructions worked, but the WIO is doing the same thing.
luwii.vanderwalt
Update 2 - Solved
Post by luwii.vanderwalt » Mon Apr 04, 2016 6:08 pm
I was given the following to try, bit obscure, but it works!
Making sure location services is enabled for the Android application makes it connect.
(I suspect it tries to work out which server to use for the backend at this point. )
yexiaobo
Post by yexiaobo » Wed Apr 13, 2016 5:40 pm
For Android 6.0 and later, must to open Location Service. Cause the new Android Permission System.
About the LED status, pls check this post:
http://www.seeedstudio.com/forum/viewto ... 786#p24786
or Here: https://github.com/Seeed-Studio/Wio_Lin ... tatus-leds
islandpacket38
Post by islandpacket38 » Sat May 14, 2016 4:37 am
I have an Galaxy Note 3, and had to turn location Services "Off" for it to locate and display Wio Link
teng.wang
Post by teng.wang » Sat May 14, 2016 10:12 am
Here 'connect server failure' message, because your WioLink need connect WioLink Server to get new WioLink Resource. But now your phone connect Wio AP which can not access network.
Can you tell me your Wio AP's name ? The app should filter and list just the "Wio_xxx" or "WioLink_xxx".
seeedstudio201410
Post by seeedstudio201410 » Sat May 14, 2016 3:59 pm
Is there any description of the protocol used by the apps to configure the WIO?
I'd rather have a linux script configuring them from my laptop.
(Still haven't got the apps to work. 10 little WIO sitting in a box... Location is certainly not blocked for the app.)
teng.wang
Post by teng.wang » Mon May 16, 2016 11:02 am
seeedstudio201410 wrote:Is there any description of the protocol used by the apps to configure the WIO?
The app use UDP protocol. And The Wio Command Line Toolset use serial.
The Wio CLI (https://github.com/Seeed-Studio/wio-cli) support Mac/Linux/Windows. You can try it.
