Wio Link Problem
Simplify IoT Development.
ischonfeld
Wio Link Problem
Post by ischonfeld » Fri Mar 25, 2016 7:42 am
I have my Wio Link up and running from the Android Phone app. For example. I have an LED on Digital0, Buzzer on Digital1 and temp/humidity sensor on Digital2. I can turn the LED and Buzzer on/off from my phone using the API screen, and get Temp and Humidity on the phone too. But if I try this from my computer:
curl –H “Authorization: token xxxxxxxx..xxx” https://iot.seeed.cc/v1/node/GroveTempHum/humidity?
It returns
<”error”: “METHOD NOT FOUND WHEN CHECK ARGS”>
Same if I try to turn the LED on/off or the Buzzer on/off (with 0 or 1 as the value. I have tried with and without the ? at the end.
Same if I try from a browser.
What is wrong with the command?
Note that xxxxxxx.xxx is my correct string, since if I don’t have the right string it says I have a bad node token.
yexiaobo
Re: Wio Link Problem
Post by yexiaobo » Wed Apr 13, 2016 5:26 pm
Normally, you will get the API URL in App like this:
Code: Select all
https://iot.seeed.cc/v1/node/GroveTempHumD0/humidity?access_token=962a6d7dca54bc4cbf01b9fc92bb49cc
If you wanna accessing Wio Link and Grove in terminal, the commend should be like this:
Code: Select all
curl -H "Authorization: token 962a6d7dca54bc4cbf01b9fc92bb49cc" https://iot.seeed.cc/v1/node/GroveTempHumD0/humidity
Not include the "?" character.
Reference: http://iot.seeed.cc/getting_started.html
