today I bought two “Wio GPS Board v1.4 05/15/2017” and wonder which
connector I will need to connect a battery to the board.
All LiPo batteries I have on hand have a slightly bigger JST connector
not fitting into the JST connector on the board.
On http://wiki.seeedstudio.com/wio_gps_board/ the connector is described
as “JST 1.0 connecter for battery”, in the schmematic I read
''JST-2P-SMD-90D".
Unfortunately I could not find out from your documentation and by
internet research what the exact specification / supplier part number of
this connector is and what item I need to order to connect a battery.
Please let me know which connector fits and if you know a shop where I
can buy batteries already having the right connector or an adapter.
Thank you in advance for your help!
Hi there,It is JST1.0 2 pin connector.
JST-2P-SMD-90D stands for the JST1.0 2pin connector. We can change the name as JST1.0 2 pins and eliminate the confusion in future products. the pin distance is 1.0mm. you can refer to below link for the cables.
<LINK_TEXT text=“https://www.aliexpress.com/store/produc … 18fdl91c4a”>https://www.aliexpress.com/store/product/10sets-Micro-Min-SH-1-0mm-Female-Male-PCB-Connector-with-Cable-DIY-Accessories-Housing-Terminals/719331_32884852901.html?spm=2114.12010612.8148356.16.2a9418fdl91c4a</LINK_TEXT> Thanksbest rgdsBill
