Where can i buy additional 11 pin kapton cable ?
During Installation the cable a shortcut occure and the cable and the 11 pin connector was damaged.
I dont know wow this could happen because the GSM BLE was off.
Regards
Urs
Regards
Urs
Even if itโs off, the power regulator supplies the 3.3V on the 11 pin connector. To be completely off, pull the battery out.
And how to fix the connector? You donโt. Try to connect the next module with the big pins on the end (the I2C and power pins are accessible there too )
Thanks for the fast answer.
Regards
Urs
