ArduinoPhone
User avatar
loovee
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by loovee » Thu Dec 27, 2012 5:03 pm
strange thing! try this one~
romny_19
Re: ArduinoPhone
Post by romny_19 » Thu Dec 27, 2012 5:05 pm
loovee wrote:strange thing! try this one~
yeep!...
yours works! thanks :)
User avatar
loovee
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by loovee » Thu Dec 27, 2012 5:05 pm
cheery314 wrote:Oh, what is the "GPRS Button" for? Does that make the phone work as a modem when connected to a PC?
hello~ it 's to start up the gprs shield.
User avatar
loovee
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by loovee » Thu Dec 27, 2012 5:07 pm
yeep!...
cheers~ but you should know that there are still something need to be modified.
romny_19
Re: ArduinoPhone
Post by romny_19 » Thu Dec 27, 2012 5:12 pm
loovee wrote:
yeep!...
well, i just wanted to look at the code.
i cant use that because i don't have all the parts necessary :/
User avatar
Jacket Chen
Staff
Staff
Which products/projects are your favorite?: Seeeduino Shields
Re: ArduinoPhone
Post by Jacket Chen » Thu Dec 27, 2012 5:37 pm
Hi all
we are just the DIY makers , and if you are interested in it , you can do it.
But never mind , we'll post more DIY modules , and you would fine a one that you can do.
If you have some interesting modules , please share it with us. ;)
Love little, love long.
User avatar
deray
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by deray » Mon Jan 28, 2013 4:35 pm
Actually , the GPRS Shield has bulit-in RCT functionality, you needn't to use another RTC module, see the At Command datasheet, you will know that.
User avatar
loovee
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by loovee » Fri Feb 15, 2013 8:24 pm
deray wrote:Actually , the GPRS Shield has bulit-in RCT functionality, you needn't to use another RTC module, see the At Command datasheet, you will know that.
yes, there is~ but it doesn't works fine somehow, you can have a try? 8-)
tpa10
Re: ArduinoPhone
Post by tpa10 » Mon Mar 11, 2013 10:50 am
OK, fessing up right up front: I'm a "noob", so please be patient with the following really stupid questions:
1. I see T-mobile has unlocked GSM cards for free, but I assume that won't do me any good if I don't have a T-mobile account, or is there a way to just communicate locally between GPRS shield and a nearby phone?
2. Is the simple solution here to buy an unlocked GSM with some account that has a limited number of hours or whatever (I don't want to add an entire new "phone" to my existing plan while I'm just experimenting)
3. In the GPRS shield Wiki it talks about installing sscom32E. My guess is that this is simply a serial line terminal program and I can just use Zmodem instead, is this correct, or is there something special about sscom32e that makes it better for interacting with the GPRS?
If I can get past these basics, I am really interested in building the phone!!
I really like your comment about the size thing too, maybe skip the pcb and use point to point wiring and some really old-fashioned enclosure. :)
User avatar
loovee
Elementary-3
Elementary-3
Re: ArduinoPhone
Post by loovee » Thu Mar 21, 2013 4:49 pm
tpa10 wrote:3. In the GPRS shield Wiki it talks about installing sscom32E. My guess is that this is simply a serial line terminal program and I can just use Zmodem instead, is this correct, or is there something special about sscom32e that makes it better for interacting with the GPRS?
about the first 2 questions~ I am not familiar to~ But I can tell you that sscom32E is just a normal serial line terminal~ take it easy, you can use any terminal as you like ! :D
