Seeeduino Cloud and Grove IoT Starter Kit issues
Any problem about ARDX kit, Grove - Starter Kit (Plus),etc, you can post here.
john_gao
Post by john_gao » Mon Apr 04, 2016 4:04 am
I get root-CA.crt from amazon, but always fail in
if((rc = myClient.config(AWS_IOT_MQTT_HOST, AWS_IOT_MQTT_PORT, AWS_IOT_ROOT_CA_PATH, AWS_IOT_PRIVATE_KEY_PATH, AWS_IOT_CERTIFICATE_PATH)) == 0) {
the rc code is -13
screen out put is:
AWS IoT SDK Version(dev) 1.1.1-
temperature
Connect failed!
-13
my box path is:
temperature
../certs/root-CA.crt
0
file no exit1
Connect failed!
-13
Do anybody real use "Seeeduino Cloud and Grove aws IOT start kit" and is working?
john_gao
Re: Seeeduino Cloud and Grove IoT Starter Kit issues
Post by john_gao » Mon Apr 04, 2016 4:31 am
The error -13 is:
the specified credentials are not found on OpenWRT
code is error in:
myClient.connect()
Do you know what tha means, I follow our the instruction, just rootCA.crt is copy from
aws-iot-device-sdk-arduino-yun
3. Download the AWS IoT CA file from here.
john_gao
Post by john_gao » Mon Apr 04, 2016 4:48 am
I fix the issue, I miss the CA file. Thanks
