Navigation Joy-stick
griseo cacir688
Post by griseo cacir688 » Fri Mar 05, 2010 6:28 pm
What is the use for the central button in the Navigation joy-stick?
How can I clear the memorized wave-form when set on the DSO the first time?
There are a few things that the manual do not refere, do you think also?
Thanks for coments.
FreeZinG
Re: Navigation Joy-stick
Post by FreeZinG » Mon Mar 08, 2010 9:27 am
about the navigation joy-stick action is all in Manual .
dagobird
Post by dagobird » Mon Mar 08, 2010 10:42 pm
FreeZinG wrote:about the navigation joy-stick action is all in Manual .
Means that the middle button has no function, as it is not described in the manual?
And how about the second question:
This is what I am interested in either!
Best Regards
dago
peterjohnston
Post by peterjohnston » Sat Mar 13, 2010 8:36 am
Yeah, the middle button doesn't do anything.
To clear the initial waveform, just make a change to the vertical or horizontal scaling. As described in the manual, the wave will disappear because the selected scaling is different to the scaling of the saved waveform.
I think the device should try to scale the waveform to the currently selected scaling and have a separate option to turn it off though...
dagobird
Post by dagobird » Sat Mar 13, 2010 10:14 pm
peterjohnston wrote: To clear the initial waveform, just make a change to the vertical or horizontal scaling. As described in the manual, the wave will disappear because the selected scaling is different to the scaling of the saved waveform.
Yeah, but how to erase it permanently?
Solved the problem in the meantime by flashing a new 3rd party firmware :roll:
Not only this issue disappeared, but also the useabilty of the interface is much more user friendly in my opinion. I found it in the depth of the internet in a chinese forum. It is from a user named yijian and has a Tek like UI.
Best Regards
dago
peterjohnston
Post by peterjohnston » Sun Mar 14, 2010 1:01 am
On this page, post 88?
Looks good - I'll have to try it!
dagobird
Post by dagobird » Sun Mar 14, 2010 3:46 am
peterjohnston wrote:On =http://translate.googleusercontent.com ... yVRZxggXbAthis page, post 88?
Exact :D (Your link was not visible, so I edited the quote a bit!)
Here is a picture of the UI:
Yijian Firmware.jpg (190.8 KiB) Viewed 6825 times
peterjohnston
Post by peterjohnston » Sun Mar 14, 2010 4:14 am
I tried it out - it looks really good and the control system makes more sense than the proper firmware, although the battery level still seems inaccurate.
peterjohnston
Post by peterjohnston » Mon Mar 15, 2010 11:21 am
I'm reverting to the original firmware. This one can't do the following:
Normal mode doesn't work - it just doesn't look like it trigers. SAME WITH Signal mode. It also can't scan.
There are pixels left behind all over the place.
It can't display the current average voltage, and other measurements.
Other than that, the control system is much better than the Seeedstudio firmware.
PhilSalkie
Post by PhilSalkie » Tue Mar 16, 2010 6:28 am
Try the "Paul" firmware - it's available from here and/or the Chinese language blog, the latest version I've seen is this:
http://www.seeedstudio.com/forum/downlo ... php?id=147
On the Chinese language page, Paul says he's not doing further development, somebody who can write Chinese should ask him to release his source code - I think this version is the most all-around usable of everything that's available.
