visualization of saved images
Moderators: lily.li, salmanfarisvp, violet, jeremy882, crail.lyu969
mauroloco
Which products/projects are your favorite?: dso nano and others
Post by mauroloco » Mon Jul 09, 2012 7:53 am
How can I visualizate on DSO nano screen a saved image on sd card to comparate two waveforms? I'm using APP 2.4 and LIB 2.2 in my dso 201
motopasscode
Kindergarten
Kindergarten
Re: visualization of saved images
Post by motopasscode » Mon Jul 09, 2012 11:13 am
I don't know how to do it with APP 2.4.
With Benf firmware APP 3.64, you:
1. go to "FI" menu
2. Save Pri, waveforms you want to compare.
3 Load Pri and Ref the waveforms from step 2.
Its a primitive way to compare but better then nothing.
You cannot View/Compare BMP images on the Nano. Only on PC.
mauroloco
Post by mauroloco » Wed Jul 11, 2012 6:48 am
Thanks!
I have two questions I've forgot to ask:
-Some cell phones have a charger with a usb output to charge their battery. Is possible use it to charge the batery of the DSO nano?
-Is there any risk of damage if I use the DSO nano to measure signals when charging their battery?
motopasscode
Kindergarten
Kindergarten
Post by motopasscode » Wed Jul 11, 2012 2:10 pm
Yes, If its a standard 5volt mini USB cellphone charger.
You can use the Nano while charging but you need to isolate Nano from the device you working on. They should not share the same ground which could be deadly for you and your Nano.
mauroloco
Post by mauroloco » Thu Jul 12, 2012 7:42 am
Ok, MOTOPASSCODE! Thank you for the help. All good for you. Warmest regards.
