SD Csrd error
mauroloco
Which products/projects are your favorite?: dso nano and others
SD Csrd error
Post by mauroloco » Sun Jul 01, 2012 6:00 am
I have a DSO 201, but I can't save thw waveforms in the SD card. Every time when I press the M key, appears the message "MICRO SD ERR." How must I proceed to save the waveforms? The APP version that I'm using is 2.4 and the library version is 2.2.
Thanks.
motopasscode
Kindergarten
Kindergarten
Re: SD Csrd error
Post by motopasscode » Sun Jul 01, 2012 12:46 pm
mauroloco wrote:I have a DSO 201, but I can't save thw waveforms in the SD card. Every time when I press the M key, appears the message "MICRO SD ERR." How must I proceed to save the waveforms? The APP version that I'm using is 2.4 and the library version is 2.2.
Thanks.
It was recommend to use SD formater https://www.sdcard.org/downloads/formatter_3/ and make sure you format as FAT16 or FAT32.
Also you might want to upgrade to Benf firmware that has better SD support.
It could also be incompatible SD Card and you need another card.
