QikPod | Issue with LinkIt Smart 7688
Can't find a proper forum to drop the topic, drop here.
Moderators: lily.li, violet
Seeed Tech Support
Post by Seeed Tech Support » Wed May 15, 2019 10:30 am
Hi Rahul,
1. How many Linkit Smart 7668 do you have?
2. What about the order ID?
3. As you mentioned that “We find that the LinkIt module overheats when we are trying to flash and also we aren't able to reboot.“, what do you flash?
4. Can they boot with the factory setting, please? thanks.
best rgds
Bill
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Wed May 15, 2019 1:32 pm
Hello Bill,
We have more than 750 LinkIts deployed with the latest order being #
4000003830.
We are trying to flash firmware v0.9.3 into the LinkIt only if it not
already is v0.9.3.
- Rahul
Anonymous
Kindergarten
Kindergarten
Hello Bill,
4000003830.
already is v0.9.3.
- Rahul
Anonymous
Kindergarten
Kindergarten
Hello Bill,
4000003830.
already is v0.9.3.
- Rahul
Seeed Tech Support
Post by Seeed Tech Support » Wed May 15, 2019 5:30 pm
Hi Rahul,
How to you update the firmware?
If you follow the web update process and fail, you can try the usb driver process by following below process.
https://docs.labs.mediatek.com/resource/linkit-smart-7688/en/tutorials/firmware-and-bootloader/update-the-firmware-with-a-usb-drive
If it still does not work, please record a video about the whole process by using the usb driver to upload the firmware. thanks.
best rgds
Bill
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Wed May 15, 2019 5:54 pm
Hi Bill,
It's done using the USB driver process itself. I'll send out the video to
you in some time.
- Rahul
Anonymous
Kindergarten
Kindergarten
Hi Bill,
you in some time.
- Rahul
Seeed Tech Support
Post by Seeed Tech Support » Wed May 15, 2019 6:01 pm
Hi
Rahul
By the way, I just break the 7688 intentionally(power off the board during firmware upgrading) and then i went through the process once again. the board is recovered and i can use the ssh to log into the board.
So if you can not boot, you can try the firmware upgrade process once again. It can solve the issue.
best rgds
Bill
