DepthEye 3D visual TOF Depth Camera on Raspbian
- Pre-kindergarten
- Pre-kindergarten
We tested it with raspberry pi and it works well, so did our customer.
Please check below items.
3. Please use CMakeLists_ubuntu_mate.txt as CMakeLists.txt to replace the old one before you run "cmake .."
1. please take a picture about your whole setup and your raspberry pi version.
2. git clone -b feature/add_support_for_Raspberry_Pi https://github.com/pointcloud-ai/DepthEyeSdk.git
best rgds
Bill
best rgds
Bill
- Pre-kindergarten
It is up to 1000fps frame rate. thanks.
best rgds
Bill
Sensor Features:
Measures Phase with QVGA(80x60)resolution
1/6" Optical Format
Up to 1000fps frame rate
Global Reset & Shutter
Programmable Features
-Frame Size, frame rate
-Exposure, ROI
De-aliasing, temp compensation
IR pass filter (820nm to 865nm)
12-bit Phase/Amplitude, 4-bit Ambient
Parallel Operating Temperature:0°C to + 70°C
best rgds
Bill
- Pre-kindergarten
When I change parameters in DepthEyeH1CDKCameraH1ForSeeed.conf,
H1AsciiSample starting and fps does not changed. When I removed this file,
sample program warnings about no config and starts with defaults 30 fps.
What should I do to apply any changes? Maybe some manual exists with rules
and restrictions of setting parameters in
DepthEyeH1CDKCameraH1ForSeeed.conf file?
Best regards!
Best regards!
