Eagleye 530s ADC
I’m using Adafruit’s electret microphone amplifier (MAX4466) who reads from adc, so i need the resolution for it.
Looking in Adafruit’s tutorial, conversion for arduino (10-bits converter) is:
[code]const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
unsigned long startMillis= millis(); // Start of sample window
unsigned int peakToPeak = 0; // peak-to-peak level
unsigned int signalMax = 0;
unsigned int signalMin = 1024;
// collect data for 50 mS
while (millis() - startMillis < sampleWindow)
sample = analogRead(0);
if (sample < 1024) // toss out spurious readings
if (sample > signalMax)
signalMax = sample; // save just the max levels
else if (sample < signalMin)
signalMin = sample; // save just the min levels
peakToPeak = signalMax - signalMin; // max - min = peak-peak amplitude
double volts = (peakToPeak * 3.3) / 1024; // convert to volts
Serial.println(volts);
}[/code]
How can i implement this in my eagleye530s?
Ps: I know how to read from adc. So, i just need to convert raw measurement to volts and then to dB.
