led module more than one
Xadow series products.
Moderators: lily.li, violet, jessie, nosk
MikeHole
Which products/projects are your favorite?: Electronic Brick
Post by MikeHole » Fri Aug 21, 2015 5:00 am
Is it possible to connect two led modules and control them independently?
kavi
Staff
Staff
Re: led module more than one
Post by kavi » Fri Aug 21, 2015 2:48 pm
Xadow LED controller in the mainboard uses only one I2C address so it is not possible to control two LED modules independently.
MikeHole
Post by MikeHole » Fri Aug 21, 2015 3:14 pm
:( so there is no way of changing code in the modules built-in microcontroller to change it's address at all?
kavi
Staff
Staff
Post by kavi » Fri Aug 21, 2015 7:53 pm
Please modify the firmware that runs on the Atmega168 to change the I2C address from http://www.seeedstudio.com/wiki/Xadow_- ... #Resources
You would require an external ISP. Use the EAGLE files to check the footprints / connections for ISP pin. They are tiny due to form factor of Xadow.
Thank you.
MikeHole
Post by MikeHole » Fri Aug 21, 2015 8:07 pm
What compiler would I use to recompile the code and can you recommend a programmer capable of writing to the chip via the pins?
Cheers,
Mike
kavi
Staff
Staff
Post by kavi » Tue Aug 25, 2015 1:56 pm
Sorry for the delayed reply.Use Arudino ISP for programming and Arduino compiler.
