LinkIt A-Core files read and delete
madaerodog
Post by madaerodog » Sat Feb 28, 2015 2:40 am
Hello, I using the A-Core to receive sms messages that I am storing in simple files, this work well, each sms has it's own file,
I am encountering a problem when trying to read them all or delete them with this code.
Read them code
Code: Select all
LFile entry;
while(true){
        entry=root.openNextFile();
        if (! entry) break;
andrei.ai [2:46 PM]
while(entry=root.openNextFile()){
Remove all code
Code: Select all
void remove_non_inbox_files(){
    LFile root = Drv.open("/Inbox");
    LFile entry;
    SeeedOled.setTextXY(0,0);
    SeeedOled.setHorizontalMode();
    while(true){
        if (! entry) break;
        char filepath[50];
        strcpy(filepath,"/Inbox/");
        strcat(filepath, entry.name());
        SeeedOled.putString(filepath);
        SeeedOled.putString("\n");
        bool deleted = Drv.remove(filepath);
        if (delete)
        // if(strcmp(entry.name(),"") != 0 && !entry.isDirectory()){
        //     Drv.remove(entry.name());
    SeeedOled.putString("  All Inbox files removed !  ");
    delay(2000);
Both codes crash the board, putting the red leds on the back in alternative blinking. Any other ideas of how to read a series of files and delete them after if needed?
Could there be a problem with retrieving files from the Linkit A-Core? Did anyone succeeded to delete any file off the memory?
Thank you.
