can`t run wifi or gprs server
back_kevin
Post by back_kevin » Sat Dec 06, 2014 7:17 am
hi i try to run the wifi server and or the gprs server
i compile the wifi server from the LinkIt-ONE-IDE/examples/Starter_Kit_for_LinkIt/Extend_Lesson/L10_Web_Temp_Advanced/L10_Web_Temp_Advanced.ino with me network name and password
after upload to the linkit one i run the serial monitor but i see nothing
same probleme with gprs server sketch
all the other sketchs works fine.
Code: Select all
 * Web Server & temperature
 * Note:
 * 1.change the WIFI_AP to your ssid of Wi-Fi
 * 2.change WIFI_PASSWORD to key of your Wi-Fi
 * 3.as well as the WIFI_AUTH
 * When the code is finish uploading, open the serial monitor
 * as soon as possible, then you can find that: "Please open your browser, and input the following address:"
 * and there will be an address below, such 192.168.1.100, copy it to your browser, press Enter,
 * then you can see the temperature.
#include <LTask.h>
#include <LWiFi.h>
#include <LWiFiServer.h>
#include <LWiFiClient.h>
#define WIFI_AP "BACK_HOME_1"
#define WIFI_PASSWORD "password"
#define WIFI_AUTH LWIFI_WPA                 // choose from LWIFI_OPEN, LWIFI_WPA, or LWIFI_WEP according to your WiFi AP configuration
LWiFiServer server(80);
float tp[10];
float getTemperature()
    static float tmp = 0.01;
    tmp += 0.01;
    return (20+tmp);
void getNewTemperature()
    float tp_new = getTemperature();
    for(int i=9; i>=1; i--)
        tp[i] = tp[i-1];
    tp[0] = tp_new;
    LTask.begin();
    LWiFi.begin();
    for(int i=0; i<10; i++)
        tp[i] = getTemperature();
    // keep retrying until connected to AP
    Serial.println("Connecting to AP");
    while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD)))
    printWifiStatus();
    Serial.println("Start Server");
    server.begin();
    Serial.println("Server Started");
int loopCount = 0;
    delay(500);
    loopCount++;
    LWiFiClient client = server.available();
    getNewTemperature();
    if (client)
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        unsigned long timer_out = millis();
        while (client.connected())
            if(millis()-timer_out > 5000)break;
            if (client.available())
                // we basically ignores client request, but wait for HTTP request end
                int c = client.read();
                Serial.print((char)c);
                if (c == '\n' && currentLineIsBlank)
                    Serial.println("send response");
                    // send a standard http response header
                    client.println("HTTP/1.1 200 OK");
                    client.println("Content-Type: text/html");
                    client.println("Connection: close");  // the connection will be closed after completion of the response
                    client.println("Refresh: 5");  // refresh the page automatically every 5 sec
                    client.println();
                    client.println("<!DOCTYPE HTML>");
                    client.println("<html>");
                    // output the value of each analog input pin
                        client.println(tp[i]);
                        client.println("<br />");
                    client.println("</html>");
                    client.println();
                    break;
                if (c == '\n')
                    // you're starting a new line
                else if (c != '\r')
                    // you've gotten a character on the current line
                    currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(500);
        // close the connection:
        Serial.println("close connection");
        client.stop();
        Serial.println("client disconnected");
void printWifiStatus()
    // print the SSID of the network you're attached to:
    Serial.print("SSID: ");
    Serial.println(LWiFi.SSID());
    // print your WiFi shield's IP address:
    IPAddress ip = LWiFi.localIP();
    Serial.println("Please open your browser, and input the following address:");
    Serial.println(ip);
    Serial.print("\r\nsubnet mask: ");
    Serial.println(LWiFi.subnetMask());
    Serial.print("gateway IP: ");
    Serial.println(LWiFi.gatewayIP());
    // print the received signal strength:
    long rssi = LWiFi.RSSI();
    Serial.print("signal strength (RSSI):");
    Serial.print(rssi);
    Serial.println(" dBm");
what can i try now
User avatar
loovee
Elementary-3
Elementary-3
Re: can`t run wifi or gprs server
Post by loovee » Sun Dec 07, 2014 10:34 am
Hi, maybe the Serial run too faster, cause you miss some log, you can add the following line to Setup() after Serial.bein(115200);
while(!Serial.available()); // until something input
while(Serial.available())Serial.read(); // clear serial data
please have a try. thanks
back_kevin
Post by back_kevin » Sun Dec 07, 2014 11:11 pm
thx i try it
i need to send a command to recive the serial output
now i see this (attachments)
when i go into the browser (mozilla) i recieve a timeout
Code: Select all
 * Note:
#include <LTask.h>
#include <LWiFi.h>
#define WIFI_PASSWORD "556890556890"
float tp[10];
    tmp += 0.01;
    return (20+tmp);
        tp[i] = tp[i-1];
    tp[0] = tp_new;
    LTask.begin();
    LWiFi.begin();
    Serial.begin(115200);
    printWifiStatus();
    server.begin();
int loopCount = 0;
    delay(500);
    loopCount++;
    if (client)
                    client.println();
                    client.println();
                    break;
                if (c == '\n')
                else if (c != '\r')
        delay(500);
        client.stop();
    Serial.println(ip);
    Serial.print(rssi);
back_kevin
Post by back_kevin » Mon Dec 08, 2014 6:00 am
ok now it works i don`t know why but it works
back_kevin
Post by back_kevin » Mon Dec 08, 2014 8:54 pm
ok the probleme was the cache in firefox
but how can i add a button to the html part to control a led
back_kevin
Post by back_kevin » Wed Dec 10, 2014 7:26 am
hi i try at the moment this code:
Code: Select all
#include <LTask.h>
#include <LWiFi.h>
#define WIFI_AUTH LWIFI_WPA// choose from LWIFI_OPEN, LWIFI_WPA, or LWIFI_WEP according to your WiFi AP configuration
// pin the LED is connected to
int ledPin = 3;
String readString; //string
boolean OUT6ON = false; // status flag
  // set the LED pin as an output
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);   // Output initialization
  LTask.begin();
  LWiFi.begin();
  printWifiStatus();
  server.begin();
  delay(500);
  if (client)
        char c = client.read();
        //    Serial.print(readString);
            if(readString.indexOf("L1=1") > -1) {//lets check if LED1 OUT6 should be on
              //led has to be turned ON
              Serial.println("LED ON");
              digitalWrite(ledPin, HIGH); // set the OUT6 on
              OUT6ON = true;
            if(readString.indexOf("L1=0") > -1) {
              Serial.println("LED OFF");
              //led has to be turned OFF
              digitalWrite(ledPin, LOW); // set the OUT6 OFF
              OUT6ON = false;
          client.println();
          // Page initialization  (remove in case You will use AJAX)
          // AJAX is about updating parts of a web page, without reloading the whole page.
          client.print(F("<html><head><title>ARDUINO WEB CONTROL</title>"));
          client.print(F("<meta http-equiv=\"refresh\" content=\"30; url=http://192.168.1.242 \" /></head><body>"));
          // IMPOTANT add main pabe link for multy user connection
          client.println("<h1>ARDUINO web control</h1>");
          //address will look like  http://192.168.1.xxx/?L=1 when submited
          client.println("<hr  />");
   client.print(F("<table border=\"1\"><tr>"));  // table start
client.print(F("<td valign=\"middle\" >"));
             if (OUT6ON) {
                  client.print(F("<a href=\"/?L1=0\">"));
                  client.print(F("<img alt=\"\" height=\"50\" width=\"50\" src=\"http://www.ercreazioni.com/ugge/led1On.PNG\"/>"));
                else
                  client.print(F("<a href=\"/?L1=1\">"));
                  client.print(F("<img alt=\"\" height=\"50\" width=\"50\" src=\"http://www.ercreazioni.com/ugge/led1Off.PNG\"/>"));
client.print(F("</td>"));
client.print(F("<form action=\"L1=1\" ><input type=\"submit\" value=\"LED 1 ON\"/></form></td>")); // first button
client.print(F("<form action=\"L1=0\" ><input type=\"submit\" value=\"LED 1 OFF\"/></form></td>"));// second button
             if (OUT6ON) {
                  client.print(F("<img alt=\"\" height=\"50\" width=\"50\" src=\"http://www.ercreazioni.com/ugge/on.jpg\"/>"));
                else
                  client.print(F("<img alt=\"\" height=\"50\" width=\"50\" src=\"http://www.ercreazioni.com/ugge/off.jpg\"/>"));
             if (OUT6ON) {
                  client.print(F("<img alt=\"\" height=\"50\" width=\"75\" src=\"http://www.ercreazioni.com/ugge/button2On.PNG\"/>"));
                else
                  client.print(F("<img alt=\"\" height=\"50\" width=\"75\" src=\"http://www.ercreazioni.com/ugge/button2Off.PNG\"/>"));
client.print(F("</tr>"));
client.print(F("</table>"));
          client.println();
          break;
        if (c == '\n')
        else if (c != '\r')
    delay(500);
    client.stop();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.print("subnet mask: ");
  Serial.print(rssi);
the web server works now
the page show my bouttoms but no reaction if i press it
the probleme come from this line
my code stop here
Code: Select all
              OUT6ON = true;
i hope you can help thx
User avatar
loovee
Elementary-3
Elementary-3
Post by loovee » Wed Dec 10, 2014 9:16 pm
Hi, I am sorry that I'm not very familiar with network programming :cry:
I will have a try later, but I don't know if I can make it!
