Page 1 of 1
device tree overlay - gpio
Posted: Sun May 08, 2016 12:47 am
by rtursen
Just got my brand new Beaglebone green. I wanted to export one of the GPIOs via the device tree overlays. I have followed the tutorial from
http://kilobaser.com/blog/2014-07-28-be ... r#1gpiodto and got below error
Code: Select all
 root@beaglebone:/lib/firmware# echo bspm_P8_13_f > /sys/devices/bone_capemgr.?/slots
-bash: echo: write error: Invalid argument
Code: Select all
 [ 5927.336871] bone-capemgr bone_capemgr.9: part_number 'bspm_P8_13_f', version 'N/A'
[ 5927.337050] bone-capemgr bone_capemgr.9: slot #11: generic override
[ 5927.337095] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 11
[ 5927.337143] bone-capemgr bone_capemgr.9: slot #11: 'Override Board Name,00A0,Override Manuf,bspm_P8_13_f'
[ 5927.337393] bone-capemgr bone_capemgr.9: slot #11: Requesting part number/version based 'bspm_P8_13_f-00A0.dtbo
[ 5927.337442] bone-capemgr bone_capemgr.9: slot #11: Requesting firmware 'bspm_P8_13_f-00A0.dtbo' for board-name 'Override Board Name', version '00A0'
[ 5927.341045] bone-capemgr bone_capemgr.9: slot #11: dtbo 'bspm_P8_13_f-00A0.dtbo' loaded; converting to live tree
[ 5927.341421] bone-capemgr bone_capemgr.9: slot #11: Incompatible with baseboard for 'bspm_P8_13_f'
[ 5927.350944] bone-capemgr bone_capemgr.9: slot #11: Failed verification
I then tried to load an existing dtbo file, PyBBIO-gpio1_13-00A0.dtbo and again got an error
Code: Select all
[ 3404.116922] bone-capemgr bone_capemgr.9: part_number 'PyBBIO-gpio1_13-00A0.dtbo', version 'N/A'
[ 3404.117102] bone-capemgr bone_capemgr.9: slot #8: generic override
[ 3404.117147] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 8
[ 3404.117195] bone-capemgr bone_capemgr.9: slot #8: 'Override Board Name,00A0,Override Manuf,PyBBIO-gpio1_13-'
[ 3404.117457] bone-capemgr bone_capemgr.9: slot #8: Requesting part number/version based 'PyBBIO-gpio1_13--00A0.dtbo
[ 3404.117507] bone-capemgr bone_capemgr.9: slot #8: Requesting firmware 'PyBBIO-gpio1_13--00A0.dtbo' for board-name 'Override Board Name', version '00A0'
[ 3404.153777] bone-capemgr bone_capemgr.9: failed to load firmware 'PyBBIO-gpio1_13--00A0.dtbo'
can you please tell me what I am doing wrong
Re: device tree overlay - gpio
Posted: Mon May 09, 2016 2:48 pm
by kavi
Copy the echo bspm_P8_13_f > /sys/devices/bone_capemgr.?/slots to rc.local file
and use the following commands
root@beaglebone:/# cd /etc
root@beaglebone:/etc# nano rc.local
hope this would resolve your issue.
Thanks and Regards
Posted: Fri May 13, 2016 3:21 pm
by rtursen
hello,
thanks for the answer. The problem seems to exist.
I did one more thing, can you please check it too
After I disabled the uart2 cape by commenting it in /boot/uEnv.txt, I was able to load universal cape without problems.
echo cape-universaln > /sys/devices/bone_capemgr.9/slot
then I wanted to have beaglebone to automatically load it at boot time so I modified /boot/uEnv.txt adding the below line
capemgr.enable_partno=cape-universaln
After this, beaglebone green stopped booting. I can't ssh into it and D2 led blinks twice per second.
I think I bricked it up. I will reflash it with an image from https://beagleboard.org/latest-images
Can you please tell me what I did wrong
