analog sensors give the same value
Applications/questions using Raspberry Pi with Seeed products, please post it here.
Moderators: lily.li, salmanfarisvp, violet
gstraath
Post by gstraath » Wed Jul 25, 2018 7:33 am
I have the grovepi light sensor on A0 and the sound sensor on A2. When I read the sensors and print I get the same value for both.
this seems … odd...
hong.jiang
Staff
Staff
Re: analog sensors give the same value
Post by hong.jiang » Wed Jul 25, 2018 9:58 am
Hi there, please provide the code and we can talk a look. thanks.
Seeed techsupport team
Bill
gstraath
Post by gstraath » Thu Jul 26, 2018 11:29 pm
it turns out I was reading the analog sensors after reading a temperature/humidity sensor on D4. putting the codeto read the analog sensors BEFORE the temp/humidity sensor solved the problem.
this specific order for accessing analog/digital sensors should possibly be mentioned somewhere in the documentation.
The complete code can be found here: https://github.com/nosarious/curiousity ... sensors.py
The specific code for the sensor values is here:
this code works, giving distinct values for analog sensors:
Code: Select all
            sensor_value0 = grovepi.analogRead(sensor0)
            sensor_value1 = grovepi.analogRead(sensor1)
            sensor_value2 = grovepi.analogRead(sensor2)
            #these analog sensor values will be distinct
            #temperature sensor data
            temperatureV = 0
            humidityV = 0
            [temp,humidity] = grovepi.dht(temp_hum_sensor,0)
            if math.isnan(temp) == False and math.isnan(humidity) == False:
                #print("temp = %.02f C humidity = %.02f%%" %(temp, humidity))
                temperatureV = temp
                humidityV = humidity
what doesn't work:
Code: Select all
            temperatureV = 0
            humidityV = 0
            [temp,humidity] = grovepi.dht(temp_hum_sensor,blue)
                temperatureV = temp
            #these analog sensor values will be the same
I am still having trouble getting information from the GPS, but I shall post that problem in a different post.
bill.yu
Junior-7
Junior-7
Post by bill.yu » Mon Jul 30, 2018 11:18 am
Hi, thanks for the sharing. please post GPS as another issue. thanks.
Bill
User avatar
salmanfarisvp
Elementary-1
Elementary-1
Which products/projects are your favorite?: Linklt One , BeagleBone Green , ReSpaker
Contact:
Post by salmanfarisvp » Sun Mar 10, 2019 12:13 am
Hu, You are Using the Analog sensor directly with Raspberry Pi...?
Start where you are, use what you have, do what you can, Share what you know.
bill.yu
Junior-7
Junior-7
Post by bill.yu » Thu Mar 28, 2019 12:30 pm
it uses the Grovepi+, it includes the atmel chip to turn the analog signal to I2C signal. thanks.
