Trouble connecting Pi 2 to Rainboduino
Applications/questions using Raspberry Pi with Seeed products, please post it here.
Moderators: violet, jessie, yexiaobo
ktf
Post by ktf » Sat Dec 05, 2015 2:16 am
I have hooked up a Raspberry Pi 2 to 6 Rainbowduinos (ARD117D2P) that I bought a few years ago and have been using with great success with an Arduino. Here is what I did
1) Using the Pi's pull up resisters I connected SLA to SLA, SCL to SCL and GND to GND.
2) Rainbowduinos respond on addresses 4-8 (verified on the Arduino)
2) I followed the directions for enabling I2C on my PI (see: https://learn.adafruit.com/adafruits-ra ... guring-i2c )
3) When I run "sudo i2cdetect -y 1" I get different results every time. Random addresses show up:
Code: Select all
pi@raspberrypi ~ $ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- 04 05 06 07 -- -- -- -- -- -- -- --
<lines deleted>
00:          -- 04 -- 06 -- 08 -- -- -- -- -- -- --
<lines deleted>
A (node.js) stub of a program fails to communicate with the the Rainbowduino. I get "Error: Cannot write to device".
Quite a bit has to be working to have devices 4-9 show up in the i2cdetect output even if intermittently but soemthing is wrong.
Has anyone had better luck connecting the Rainbowduino to the Pi? Has anyone see a problem like this?
Thanks so much.
Ken
