Will this product work with a vesa wall mount mounting points need to be between 75mm 100mm https://www.seeedstudio.com/10-1-inch-1200-1980-HDMI-IPS-LCD-Display-p-2863.html#
The current plate does not have the wall fix holes. But you can drill the wholes on the plate and then install on the wall. How many pcs do you need? If there is a big order, we can request the factory to change the design.
best rgds
Bill
