shield NFC V2 effective range
The nfc shield V2 has 5cm max effective range with its antenna.
Is it possible to have 10cm max range ?
With new antenna or card modification?
Hi there~
You can redesign the antenna to achieve the reading range. thanks.
Thank. Do you have best practive to do that.
I want to capture information for nfc mifare tag from 7 to 10 cm. The tag is moving.
Thank
gin
