Relay Shield Power PIN Not Connected?
On the Relay Shield is a 9 Volt port Screw terminal. (Left of the Power Connector with power connector pointing down).
From what I can tell it is not connected to the VIN 9 Volt Bus.
I have tried Both 9 Volt Jacks (Shield/Arduino) and it appears they don’t go connect to the Screw Terminal. :astonished:
Not a big deal to wire up. I just want to confirm it is not connected.
Thanks,
Neal
Hi customer,
You can view the Eagle file to know it.
seeedstudio.com/wiki/images/ … eFiles.zip
Hope can help you.
