DSOQuadV2.6 RESOURCE(Update 2012/04/12)
Ducatirocks
Which products/projects are your favorite?: ds203v2.6
Re: DSOQuadV2.6 RESOURCE(Update 2011/7/22)
Post by Ducatirocks » Wed Sep 28, 2011 11:33 pm
Ducatirocks wrote:Not sure about line at display before cal. Ater it was at middle I suppose.
Mode was DC I suppose.
Why? Should I try AC?
I just tried with ac and 10v/div... Result was the same...
chip
Which products/projects are your favorite?: DSO
Post by chip » Thu Sep 29, 2011 12:31 am
1) Both analog channels probes (x1) was eathed. Probe earthing crocodile to probe tip.
2) Automatic calibration sequence was started with "stop" button (2 s).
3) Sequence was completed and all levels achieved Zero.
4) All asked volts was added to each level and fine tuned to same as digital volt meter reading.
5) Calibration saved as asked ("Press "stop" to confirm the re-calibration CH-A")
two points are not clear.
photo with the correct calibration
chip
Post by chip » Thu Sep 29, 2011 12:43 am
and more, 8 bits = 255 values.
10v/div *8div = 80V
accuracy 80/255 = 0.3V
(without ofset)
Ducatirocks
Post by Ducatirocks » Thu Sep 29, 2011 3:49 am
chip wrote:and more, 8 bits = 255 values.
10v/div *8div = 80V
(without ofset)
WTF!
Is this 150 bucks oscilloscope or what!! At least quad was sold to me as an revolutionary oscilloscope. I was waiting some more than this!
I apologies my thoughts....
Please. answer my offset problem!
menniti
Which products/projects are your favorite?: DSO QUAD v.2.60
Post by menniti » Thu Sep 29, 2011 5:39 pm
10v/div *8div = 80V
(without ofset)
I apologize but I do not understand the language (I use google translator). So it is normal to see 0.2 to 0.3 volts in the absence of signal with the probe grounded?
dickda1
Post by dickda1 » Thu Sep 29, 2011 10:28 pm
I agree with chip. The published calibration procedure does not agree with the results shown on the screen. :?
It is difficult to tell if the calibration is stored successfully or is complete.
Being a great engineer with good language skills is a rare combination.
You need to get a document writer with good English skills to review the docs. How about publishing a YouTube video on V2.6 calibration?
menniti
Post by menniti » Thu Sep 29, 2011 10:31 pm
I downloaded the update FPGA_V2.5
I read in the manual which is not recommended to do this update.
What is it?
It should do so or to avoid?
thanks
goliath11
Which products/projects are your favorite?: DSO nano
Post by goliath11 » Fri Sep 30, 2011 10:32 am
10v/div *8div = 80V
(without ofset)
I very much doubt that this is a limitation, my friend's DSO nano v2 measures exactly 0V when the probe is grounded. According to him he has never calibrated it.
menniti
Post by menniti » Fri Sep 30, 2011 2:45 pm
Thanks for the reply, I did the calibration several times, successfully, saving the parameters, I'm writing a manual in Italian (14 A4 pages!) of this oscilloscope and I can say to use it well.
The lowest flow rates (and not on the 10V/div) do not give 0.00V with the probe grounded. However, I still repeat the calibration.
Tnx
PS: The official manual v.0.92b explains that the internal generator can provide a square wave with adjustable duty cycle, but I do not find it anywhere this duty cycle regulation.
chip
Post by chip » Sun Oct 02, 2011 5:09 am
