DSOQuadV2.6 RESOURCE(Update 2012/04/12)
HugeMan
Elementary-2
Elementary-2
Which products/projects are your favorite?: DSO
Post by HugeMan » Fri Apr 15, 2011 10:13 am
DSO Quadv2.6Manual released..Include the basic operation and upgrade methed. and firmware include :logo related file, FPGA logic file, App.hex and Sys.hex.
NOTE: firmware for HWv2.2 is not compatible with HWv2.6 . DO NOT upgrade HWv2.6 with firmware for HWv2.2
Latest firmware available(2012/04/12):
APP: 2.53
SYS: 1.52
FPGA: 2.61
logo: logo file , do not need to upgrade as you do not want to.
And, a new designer has joined to design the UI. The following firmware available:(2012/02/14) )
APP:AP3_P100
please ref the wiki to track the latest firmware:
http://garden.seeedstudio.com/index.php ... mware_List
Firmwares that needs to be installed into the DSO Quad:
1. CFG_FPGA.ADR + VxxxFPGA.bin. The two files for fpga logic, you need to install the .ADR file and then the .bin file.
2. logo_00B.ADR + logo_001.bin. the logo files, need to install the .ADR file and then the .bin file.
3. APP_Bxxx.hex, the app firmware.
4. SYS_Bxxx.hex, the sys firmware.
when you want to update you firmware, for example, you want to update the app firmware to v2.35 to corrrect the calibration error ,you just need to update the app ,to 2.35, as there is no update in the sys firmware.
you should do:
1. download the app 2.35 zip from below lines.
2.upzip the app, you would see app_B235.hex and DSO Quad Calibration .pdf.
3. connect the Quad to PC via USB , and power Quad with the ">||"pressed.
4.copy the App_B235 to the virtual disk . the virtual disk will auto reset and this file changes to :APP_B235.RDY.
5. Update finished. calibrate the Quad as the DSO Quad Calibration .pdf
updated issue:
1.sys1.34 and .app2.32 can be download now, Please upgrade your DSO QuadHWv2.6 ASAP (2011/4/19)
2.Manual 0.91B added(2011/4/22)
3.Manual to calibrate the probes added(2011/4/25)
4.App 2.33 added(2011/4/27)
5.App 2.35 added,the calibration error been corrected.(2011/5/16)
6.FPGA_V2.5 added(2011/5/18)
7.Manual 0.92B added(2011/5/30)
8.Sys1.37 added(2011/06/01)
9.App2.43 added(2011/06/07)
10.Sys1.41 added(2011/06/07)
11 App2.45 added(2011/06/16)
12 App2.45(b) added(2011/06/17)
13 App2.50 and Sys1.50 added(2011/07/11)
14 New UI ,just for testing!!(2011/07/22)
15 app252/sys151/fpga2.6 released..
16.AP3_P100 released, this is not a offical Version
17. APP2.53 and Sys1.52 released(2012/04/12)
DS203 new firmware testing.rar
New UI ,just for testing ...if you do not like something that is not finished yet , please do not try.
(52.85 KiB) Downloaded 2613 times
SYS_B150.zip
1.Re-write the fat12 file system (FAT12.c,ASM.s)
2.Modified read/write flash functions(Memory.c, EXT_flash.c)
you need to format the Quad disk after upgrading as http://www.seeedstudio.com/forum/viewtopic.php?f=22&t=2112
(20.46 KiB) Downloaded 3613 times
APP_B250.zip
1. re-write the file.c and asm.s based on the new fat32 file sys.
2. Modified the TH TL measure bugs in Menu.c
3.Optimize the measuring related functions (Menu.c ,Function.c,Calibrat.c)
4. Modified the bugs in triggering with pulse width.
(30.65 KiB) Downloaded 3673 times
APP_V245(b).rar
modifyed the bug in calibration channel B in app245
(35.74 KiB) Downloaded 2584 times
APP_V245.rar
1. Modified the bug in saving the setting
2. Modified the bug in saving the calibration data
(35.74 KiB) Downloaded 1949 times
sys141.rar
1. Read/Write file system functions added(DOSFS.C)
2. Debug the bugs in read BUFF(DOSFS.C)
(22.83 KiB) Downloaded 2434 times
App_V243.rar
1. Auto calibration added(calibrat.c,process.c,function.c)
2.frequency and duty measure added(Process.c,Menu.c)
3. Function to export the data in .CSV added(Main.c,files.c Menu.c)
4.Must be used with SysV1.40 or above.
(35.44 KiB) Downloaded 2826 times
SYS_B137.rar
1. debug the saving error that may led to a black screen in sys1.34
2. dubug the function to set the offset to CH_A and CH_B
(18.26 KiB) Downloaded 1274 times
DSO Quad v2 6 Manual 0.92b.rar
1. how to calibrate the probe added.
2. how to calibrate the waveform added
(2.51 MiB) Downloaded 17027 times
FPGA_V2.5.zip
1. function to set sample depth added.
2. function to set trigger delay added
(23.59 KiB) Downloaded 1930 times
App2.35 and Quad calibration.zip
app 2.35, the calibration error been corrected.
(33.36 KiB) Downloaded 1777 times
APP2.33.zip
(24.46 KiB) Downloaded 1471 times
How to adjust the C to calibrate the probes.zip
(74.25 KiB) Downloaded 4290 times
DSOQuadV2.6Manual0.91B.zip
(2.57 MiB) Downloaded 13208 times
SYS1.34 AND APP2.32.zip
SYS1.34 and APP2.32 , please upgrade all the files include FPGA file(2011/04/19)
(63.14 KiB) Downloaded 1721 times
Save wave for DSOQuad.rar
module to save the waveform to .bmp file or .dat file
(4.06 KiB) Downloaded 6138 times
DS203V2 6_SCH.rar
QuadV2.6 hardware SCH
(62.06 KiB) Downloaded 25623 times
Quad firmware.rar
.sys 1.31 and .app 2.30
(58.65 KiB) Downloaded 2571 times
HugeMan
Elementary-2
Elementary-2
Re: DSOQuadV2.6Manual
Post by HugeMan » Fri Apr 15, 2011 10:50 am
APP(V2.32) sourcecode released:
SYS(V1.34) sourcecode released:
APP(V2.35) sourcecode released:
FPGA(V2.5) sourcecode released:
and , for some reason, the sourcecode git change
https://github.com/Seeed-Studio/DSOQuad ... SourceCode
to :
https://github.com/Seeed-Studio/DSOQuad_SourceCode
malysh2011
Which products/projects are your favorite?: DSO QUAD v2.6 Oscilloscope
Post by malysh2011 » Mon Apr 18, 2011 2:41 am
Is there new firmware? :oops:
fdufnews
Kindergarten
Kindergarten
Re: DSOQuadV2.6 RESOURCE(Update 2011/4/19)
Post by fdufnews » Tue Apr 19, 2011 6:32 pm
Can we know what SYS1.34 and APP2.32 change to the previous version?
Bainesbunch
Elementary-1
Elementary-1
Post by Bainesbunch » Tue Apr 19, 2011 9:47 pm
A change log would be usefull when upgrading Firmware so we know what to expect :)
rich
Elementary-1
Elementary-1
Post by rich » Mon Apr 25, 2011 6:49 am
I can not upgrade on a Mac, if I boot the device in upgrade mode it continually resets itself so that disk is disappearing faster than I can copy to it. Is there another way, DFU-util or dfuse that I can use.
So I found a Windoze box and it is clear now what the problem is, and it should be simple to fix. Are you interested in fixing it or should I go off and do it myself? I hate seeing forked pools, but this is very annoying. We got the dfuse tool working for the previous mode, not I but others did that which gave us the ability to update from many different platforms. I am not excited by going backwards here.
HugeMan
Elementary-2
Elementary-2
Post by HugeMan » Mon Apr 25, 2011 9:27 am
rich wrote:I can not upgrade on a Mac, if I boot the device in upgrade mode it continually resets itself so that disk is disappearing faster than I can copy to it. Is there another way, DFU-util or dfuse that I can use.
The DSOQuad HWv2.6 need to upgrade the app/sys/FPGA as the way in the manual because of the BIOS that embeded in the STM32 when Quad was produced . So, DFU-util or dfuse can not be used unless you embeded the related BIOS to the STM32.
as on the Mac, it will be grateful for you sharing your experience that we really lacked .I expececd your detailed introduction
rich
Elementary-1
Elementary-1
Post by rich » Tue Apr 26, 2011 12:17 pm
HugeMan wrote: The DSOQuad HWv2.6 need to upgrade the app/sys/FPGA as the way in the manual because of the BIOS that embeded in the STM32 when Quad was produced . So, DFU-util or dfuse can not be used unless you embeded the related BIOS to the STM32.
Please tell me what you need to know and I will write it up. On Linux or a Mac the upgrade disk disappears completely every time it checks for new files. (about every second or two) This interrupts copies, or truncates them, and umounts the drive about as fast as the OS can mount it. This makes it so that you can't copy anything reliably. I even tried to write a script to detect the disk had reappears and then did an ordered copy of the files, but that failed as well. Windows seems to tolerate the disk disappearing for a moment, but Linux and Mac os treat it as if the drive was unplugged while active. So the experience on Windows is good, but it is unusable on Mac os or Linux, even from a program trying to interact with it.
Is this what you need or is it something else? I am willing to help, but it is hard to know what someone doesn't know. If I were going to fix it, I would change the embedded code to wait for a button press before disconnecting to check for new/changed files. That way you could succeed on copying the files on, before the system sees the disk go away as it now does.
retlif
Re: DSOQuadV2.6 RESOURCE(Update 2011/4/27)
Post by retlif » Wed Apr 27, 2011 1:05 pm
Hi
We just received our engineering sample today.
As suggested by the developers, we upgraded the APP to 2.33 and the other SYS f/w updates.
However, now the CALIBRATE button does not work.
Please advice.
HugeMan
Elementary-2
Elementary-2
Post by HugeMan » Wed Apr 27, 2011 1:41 pm
retlif wrote:Hi
Please advice.
you may need to pressed this button about 2s...
