Avrdude fails programming RFBee V1.1 in Grove XBee Carrier
richardbroberg
Post by richardbroberg » Mon Feb 16, 2015 12:51 am
Arduino 1.5.6-r.2 board is Arduino Pro or Pro Mini
Source is RFBee with TM1637 library referenced to set 4 digit display to 1234 in setup
Seems like there is plenty of room:
Sketch uses 11,698 bytes (38%) of program storage space. Maximum is 30,720 bytes.
Global variables use 592 bytes (28%) of dynamic memory, leaving 1,456 bytes for local variables. Maximum is 2,048 bytes.
Any suggestions?
richardbroberg
Re: Avrdude fails programming RFBee V1.1 in Grove XBee Carri
Post by richardbroberg » Mon Feb 16, 2015 4:41 am
Jumper RFBee DTR to ground.
Board is Arduino Pro or Pro Mini
Processor is ATmega 168(3.3v, 8 MHz)
Jumper RFBee reset to ground while Arduino ide is compiling and for about a second after the IDE switches state to uploading and then remove the jumper.
richardbroberg
Post by richardbroberg » Tue Feb 17, 2015 1:02 am
Simplest solution is to connect .47 uF cap between DTR and Reset
dooori45
Post by dooori45 » Sun Apr 05, 2015 3:09 am
Any ideas why a bluetooth bee will successfully become inquirable but then fail (go nin-inquirable) when attempting to pair a laptop or an android device with it?
dolii
User avatar
Jacket Chen
Staff
Staff
Which products/projects are your favorite?: Seeeduino Shields
Post by Jacket Chen » Tue Apr 07, 2015 3:08 pm
richardbroberg wrote:Simplest solution is to connect .47 uF cap between DTR and Reset
Yes, you're right. Auto-program AVR chip via FTDI device, we always add a 100nF cap between DTR and Reset.
Jacket
Love little, love long.
User avatar
Jacket Chen
Staff
Staff
Post by Jacket Chen » Tue Apr 07, 2015 3:13 pm
dooori45 wrote:Any ideas why a bluetooth bee will successfully become inquirable but then fail (go nin-inquirable) when attempting to pair a laptop or an android device with it?
Sounds strange, could you show more details how it happened?
Jacket
