128x128 oled
Moderators: lily.li, violet, salmanfarisvp, jeremy882, crail.lyu969
bobgardner
128x128 oled
Post by bobgardner » Mon Sep 17, 2018 10:55 am
I have several oled displays 128x32, 128x64, both spi and i2c versions. I bought the grove 128x128, and I can run the seeedgrayoled arduino sketch and see 12 lines of hello world in the 96 by 96 box, but thats not a very good example. It should at least be able to draw lines. The 128x128 display with the sh1107 controller is not a gray scale controller. Very confusing. I have been trying to compile a program using c to init the controller and fill and clear the screen in pagemode, 16 pages 8 pixels hi and 128 pixels wide. If any programmer out there with one of these displays has written an sh1107 init and clear and fill screen and maybe a setpixel and clearpixel using the sh1107 read-modify-write opcode pair, I would like to see a picture of the screen. Thanks. If Bill Yu is reading this, you asked me to send a picture of my display that says its version 1.1, and I sent a private message to you a while ago, but no reply so far. Thanks.
bill.yu
Junior-7
Junior-7
Re: 128x128 oled
Post by bill.yu » Tue Sep 18, 2018 7:41 pm
Sorry, i missed the message. do you use https://github.com/Seeed-Studio/OLED_Di ... SH1107G_v2 examples? thanks.
best rgds
Bill
bobgardner
Re: 128x128 oled
Post by bobgardner » Thu Sep 20, 2018 12:43 am
Hello again Bill. Did seeed build and sell a 128x128 1.12" oled v1.1? Thats what the picture shows. It must have a sino wealth sh1107 controller on it. Are the commands the same for all versions of this controller? I cant find a datasheet for the sh1107z. Do you have it? Can you put it in the documents folder for grove parts?
xianning.lan
Re: 128x128 oled
Post by xianning.lan » Fri Sep 28, 2018 3:46 pm
Hi, there. I found that datasheet in Seeed Wiki, this is the link: https://github.com/SeeedDocument/Grove_ ... asheet.pdf, I hope it could help you. Thanks.
sypniewski
Re: 128x128 oled
Post by sypniewski » Thu Nov 01, 2018 2:43 am
I have a 128x128. I clicked on the download button and I got a library for the 96x96. The sketches compile but nothing appears on the screen. Explain this to me. Is there a separate library for the 128x128?
User avatar
olikraus
Re: 128x128 oled
Post by olikraus » Tue Apr 23, 2019 4:35 am
I have finished support for the Grove 128x128 V2 (with SH1107) for u8g2. All the u8g2 functionality should be available now. See also my answer here: viewtopic.php?f=56&t=31555&p=52752&hilit=oled#p52752
Oliver
areej.594
Re: 128x128 oled
Post by areej.594 » Wed Apr 24, 2019 1:56 am
alina06
Re: 128x128 oled
Post by alina06 » Wed Apr 24, 2019 3:41 am
I have several oled displays 128x32, 128x64, both spi and i2c versions. I bought the grove 128x128, and I can run the seeedgrayoled arduino sketch and see 12 lines of hello world in the 96 by 96 box, but thats not a very good example. FileZilla UC Browser Rufus It should at least be able to draw lines. The 128x128 display with the sh1107 controller is not a gray scale controller. Very confusing. I have been trying to compile a program using c to init the controller and fill and clear the screen in pagemode, 16 pages 8 pixels hi and 128 pixels wide. If any programmer out there with one of these displays has written an sh1107 init and clear and fill screen and maybe a setpixel and clearpixel using the sh1107 read-modify-write opcode pair, I would like to see a picture of the screen. Thanks. If Bill Yu is reading this, you asked me to send a picture of my display that says its version 1.1, and I sent a private message to you a while ago, but no reply so far. Thanks.
User avatar
olikraus
Re: 128x128 oled
Post by olikraus » Sun May 19, 2019 3:05 pm
I have added support for the new sh1107 Grove display to U8g2 Arduino Library:
https://github.com/olikraus/u8g2/wiki/g ... tudio-oled
Support is there in v2.26, however v2.26 is not yet released as of today.
Follow the instructions here to install the U8g2 beta release: https://github.com/olikraus/u8g2/issues/877
Oliver
bill.yu
Junior-7
Junior-7
Re: 128x128 oled
Post by bill.yu » Mon May 20, 2019 10:21 am
Hi Oliver,
thanks for your efforts to add the oled into U8g2 library. thanks.
