OLED 128x64 - Print a float
Moderators: lily.li, violet, salmanfarisvp, jeremy882, crail.lyu969
burchd
Post by burchd » Tue Jan 22, 2013 12:13 pm
I have a DS18s20 temperature sensor which gives a 2 decimal place float as an output. Something like 21.95.
Can you give me a code example of how to print it to the screen? I keep getting a type conversion error
Invalid conversion from Char to unsigned char.
I am printing to the screen fine.
Also, can you give me an example of how to print a string variable.
This is fine...
unsigned char fill_string5a[]="00.00";
But if i do something like.
String stTemp = ltoa(temperature, buffer, 10);
sendStr(stTemp);
I get invalid conversion from string to unsigned char.
I am using Arduino 1.0.3
thanks in advance...
David...
User avatar
Jacket Chen
Staff
Staff
Which products/projects are your favorite?: Seeeduino Shields
Re: OLED 128x64 - Print a float
Post by Jacket Chen » Wed Jan 23, 2013 9:20 am
burchd wrote:I have a DS18s20 temperature sensor which gives a 2 decimal place float as an output. Something like 21.95.
SeeedOled.putFloat(21.95);
burchd wrote:can you give me an example of how to print a string variable
float fill_string5a;
SeeedOled.putFloat(fill_string5a);
Love little, love long.
burchd
Post by burchd » Thu Jan 24, 2013 11:31 am
Am i using the wrong library? Can i use the seeedoled one?
i only have
sendStr(fill_string6);
sendChar(fill_string6);
This was listed in the grove instructions.
User avatar
Jacket Chen
Staff
Staff
Post by Jacket Chen » Mon Jan 28, 2013 2:44 pm
Yes , you could use SeeedOLED libraries.
burchd
Post by burchd » Tue Jan 29, 2013 11:06 am
That works great! thankyou....
User avatar
Jacket Chen
Staff
Staff
Post by Jacket Chen » Tue Jan 29, 2013 11:54 am
Enjou yourself.
