Replace water flow sensor in kit
Hi Seeedstudio,
I already have one “Grove Smart Plant Care”-kit and I want to order
additional two “Grove Smart Plant Care”-kit but the flow sensor that is
included in the kit have a different hose fitting diameter than the water
pump that comes with same kit.
At your site is another flow sensor available (same price) with only
difference that it has correct hose fittings (8 mm).
Hi Oliver,
Please try below setup. you need 2 kinds of tube for the connection.
1. the water flow is 1/4 inch, you need the 1/4 inch tube connect both water flow sensor and converter 1/4 inch side.
2. you also need a 1/8 inch tube to connect both converter 1/8 inch side and the pump.
For the water flow sensor replacement, I feedback to product manager. It will be much easier, you can connect the water flow sensor to pump directly with 1/8 inch tube.
thanks.
best rgds
Bill
Ok I will try this right away. But I want to know the outer diameter size of the hose fittings for the flow sensor specified in the link below.
-Can you please measure the diameter of the inlet/outlet fittings of this flow sensor https://www.seeedstudio.com/G1-8-Water-Flow-Sensor-p-1346.html
Br
//Oliver
Hi
Oliver
The inlet/outlet fittings of yf-s401 is 2mm/7mm.
best rgds
Bill
