Can i use the grove speech recognizer kit for arduino to make a lamp voice controlled
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Thu Apr 11, 2019 4:33 am
Can i use the grove speech recognizer kit for arduino to make a lamp voice controlled?
Seeed Tech Support
Post by Seeed Tech Support » Thu Apr 11, 2019 9:08 am
HI there You have to buy arduino and grove-relay(NOT included) to make the lamp controlled by voice.
https://www.seeedstudio.com/Seeeduino-L ... -2896.html
http://wiki.seeedstudio.com/Grove-Relay/
You can refer below voice command, for more info, please refer to http://wiki.seeedstudio.com/Grove-Speech_Recognizer/
Command
Value
Turn on the light
1
Turn off the light
2
Play music
3
Pause
4
Next
5
Previous
6
Up
7
Down
8
Turn on the TV
9
Turn off the TV
10
Increase temperature
11
Decrease temperature
12
What’s the time
13
Open the door
14
Close the door
15
Left
16
Right
17
Stop
18
Start
19
Mode 1
20
Mode 2
21
Go
22
thanksbest rgdsBill
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Thu Apr 11, 2019 10:51 pm
Thank you, also are there any tutorials and codes for the grove relay? I’ve been looking online and can’t find anything
Sent from my iPhone
Seeed Tech Support
Post by Seeed Tech Support » Fri Apr 12, 2019 9:53 am
Hi there
You can check http://wiki.seeedstudio.com/Grove-Relay/ , it is digital signal.
best rgds
Bill
