Grove Breadboard
baqwas
Grove Breadboard
Post by baqwas » Fri May 10, 2019 1:36 am
Quick question: Is there any particular reason (or am I missing the concept) why the traditional pair of VCC/GND bus was omitted from the design?
Also, will there be a baseplate (for order) to mount all the Grove devices (as illustrated in the email note)? A baseplate can be easily prepared from a hardware shop purchase (as I did for the Grove Irrigation Kit) but something with etches (along the lines of something useful for beginners with a starter kit) to hit the ground running. Just a thought.
Regards.
bill.yu
Elementary-5
Elementary-5
Re: Grove Breadboard
Post by bill.yu » Fri May 10, 2019 10:26 am
It it limited by the space. you can use the vertical line for the vcc and gnd. For the second input, i will feedback to product manager. thanks.
nicho810
Post by nicho810 » Fri May 10, 2019 11:29 am
I made a baseplatefor testing, maybe it will help you, get the file here~ or attachments
https://github.com/nicho810/somethingAb ... Breadboard
In addition, there is a PSD file for drawing breadboard sketches, which I believe will be helpful in actual use or when doing tutorials.
Grove-Breadboard Sketch.zip
(600.82 KiB) Downloaded 8 times
Grove kit baseplate Test 0.3.dxf.zip
(52.35 KiB) Downloaded 9 times
Grove - Breadboard - PSD preview.png (75.04 KiB) Viewed 240 times
Grove - Breadboard - DXF preview.png (23.43 KiB) Viewed 240 times
Grove - Breadboard - DXF example.jpg (1.71 MiB) Viewed 240 times
bill.yu
Elementary-5
Elementary-5
Post by bill.yu » Mon May 13, 2019 11:24 am
thanks for the sharing.
