Remove "Hat Name = 'Grove Base Hat RPi'" from python
Hello i have been trying to edit some of the example code for a few sensors:
<LINK_TEXT text=“https://github.com/Seeed-Studio/grove.p … _sensor.py”>https://github.com/Seeed-Studio/grove.py/blob/master/grove/grove_temperature_humidity_sensor.py</LINK_TEXT>
[code]#!/usr/bin/env python
This code is for
Grove - Temperature & Humidity Sensor (DHT11)
(https://www.seeedstudio.com/Grove-Temperature-Humidity-Sensor-DHT1-p-745.html)
Grove - Temperature & Humidity Sensor Pro (AM2302)
(https://www.seeedstudio.com/Grove-Temperature-Humidity-Sensor-Pro-AM230-p-838.html)
which is consists of a capacitive sensor element used for measuring relative humidity
and a negative temperature coefficient(NTC) thermistor used for measuring temperature.
This is the library for Grove Base Hat which used to connect grove sensors for raspberry pi.
import RPi.GPIO as GPIO
from grove.helper import *
def set_max_priority(): pass
def set_default_priority(): pass
from time import sleep
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
PULSES_CNT = 41
class DHT(object):
DHT_TYPE = {
‘DHT11’: ‘11’,
‘DHT22’: ‘22’
MAX_CNT = 320
def __init__(self, dht_type, pin):
    self.pin = pin
    if dht_type != self.DHT_TYPE['DHT11'] and dht_type != self.DHT_TYPE['DHT22']:
        print('ERROR: Please use 11|22 as dht type.')
        exit(1)
    self.dht_type = dht_type
    GPIO.setup(self.pin, GPIO.OUT)
    self._last_temp = 0.0
    self._last_humi = 0.0
@property
def dht_type(self):
    return self._dht_type
@dht_type.setter
def dht_type(self, type):
    self._dht_type = type
def _read(self):
    # Send Falling signal to trigger sensor output data
    # Wait for 20ms to collect 42 bytes data
    set_max_priority()
    GPIO.output(self.pin, 1)
    sleep(.2)
    GPIO.output(self.pin, 0)
    sleep(.018)
    GPIO.setup(self.pin, GPIO.IN)
    # a short delay needed
    for i in range(10):
        pass
    # pullup by host 20-40 us
    count = 0
    while GPIO.input(self.pin):
        count += 1
        if count > self.MAX_CNT:
            # print("pullup by host 20-40us failed")
            return None, "pullup by host 20-40us failed"
    pulse_cnt = [0] * (2 * PULSES_CNT)
    fix_crc = False
    for i in range(0, PULSES_CNT * 2, 2):
        while not GPIO.input(self.pin):
            pulse_cnt[i] += 1
            if pulse_cnt[i] > self.MAX_CNT:
                # print("pulldown by DHT timeout %d" % i)
                return None, "pulldown by DHT timeout %d" % i
            pulse_cnt[i + 1] += 1
            if pulse_cnt[i + 1] > self.MAX_CNT:
                # print("pullup by DHT timeout %d" % (i + 1))
                if i == (PULSES_CNT - 1) * 2:
                    # fix_crc = True
                    # break
                    pass
                return None, "pullup by DHT timeout %d" % i
    # back to normal priority
    total_cnt = 0
    for i in range(2, 2 * PULSES_CNT, 2):
        total_cnt += pulse_cnt[i]
    # Low level ( 50 us) average counter
    average_cnt = total_cnt / (PULSES_CNT - 1)
    # print("low level average loop = %d" % average_cnt)
    data = ''
    for i in range(3, 2 * PULSES_CNT, 2):
        if pulse_cnt[i] > average_cnt:
            data += '1'
        else:
            data += '0'
    data0 = int(data[ 0: 8], 2)
    data1 = int(data[ 8:16], 2)
    data2 = int(data[16:24], 2)
    data3 = int(data[24:32], 2)
    data4 = int(data[32:40], 2)
    if fix_crc and data4 != ((data0 + data1 + data2 + data3) & 0xFF):
        data4 = data4 ^ 0x01
        data = data[0: PULSES_CNT - 2] + ('1' if data4 & 0x01 else '0')
    if data4 == ((data0 + data1 + data2 + data3) & 0xFF):
        if self._dht_type == self.DHT_TYPE['DHT11']:
            humi = int(data0)
            temp = int(data2)
        elif self._dht_type == self.DHT_TYPE['DHT22']:
            humi = float(int(data[ 0:16], 2)*0.1)
            temp = float(int(data[17:32], 2)*0.2*(0.5-int(data[16], 2)))
    else:
        # print("checksum error!")
        return None, "checksum error!"
    return humi, temp
def read(self, retries = 15):
    for i in range(retries):
        humi, temp = self._read()
        if not humi is None:
            break
    if humi is None:
        return self._last_humi, self._last_temp
    self._last_humi,self._last_temp = humi, temp
    return humi, temp
Grove = DHT
def main():
from grove.helper import SlotHelper
sh = SlotHelper(SlotHelper.GPIO)
pin = sh.argv2pin(" [dht_type]")
import sys
typ = '11'
if len(sys.argv) >= 3:
    typ = sys.argv[2]
import time
sensor = DHT(typ, pin)
while True:
    humi, temp = sensor.read()
        print('DHT{0}, humidity {1:.1f}%, temperature {2:.1f}*'.format(sensor.dht_type, humi, temp))
    else:
        print('DHT{0}, humidity & temperature: {1}'.format(sensor.dht_type, temp))
    time.sleep(1)
if name == ‘main’:
main()
[/code]
<LINK_TEXT text=“https://github.com/Seeed-Studio/grove.p … or_v1_2.py”>https://github.com/Seeed-Studio/grove.py/blob/master/grove/grove_light_sensor_v1_2.py</LINK_TEXT>
-- coding: utf-8 --
The MIT License (MIT)
Grove Base Hat for the Raspberry Pi, used to connect grove sensors.
Copyright © 2018 Seeed Technology Co.,Ltd.
This is the code for
- Grove - Light Sensor <https://www.seeedstudio.com/Grove-Light-Sensor-v1.2-p-2727.html>_
Examples:
… code-block:: python
import time
from grove.grove_light_sensor import GroveLightSensor
# connect to alalog pin 2(slot A2)
PIN = 2
sensor = GroveLightSensor(pin)
print(‘Detecting light…’)
while True:
print(‘Light value: {0}’.format(sensor.light))
time.sleep(1)
import time, sys, math
from grove.adc import ADC
all = [“GroveLightSensor”]
class GroveLightSensor(object):
Grove Light Sensor class
Args:
pin(int): number of analog pin/channel the sensor connected.
def init(self, channel):
self.channel = channel
self.adc = ADC()
@property
def light(self):
    Get the light strength value, maximum value is 100.0%
    Returns:
        (int): ratio, 0(0.0%) - 1000(100.0%)
    value = self.adc.read(self.channel)
    return value
Grove = GroveLightSensor
def main():
sh = SlotHelper(SlotHelper.ADC)
pin = sh.argv2pin()
print('Detecting light...')
while True:
    print('Light value: {0}'.format(sensor.light))
    time.sleep(1)
if name == ‘main’:
main()
[/code]
It works and i get a value, but it says “Hat Name = ‘Grove Base Hat RPi’” everytime i run the file, i would really like to remove this and have it only return a number.
Iv looked through the code for both of those files and cant seem to figure out how to get rid of it, i think its getting that from another file:
<LINK_TEXT text=“https://github.com/Seeed-Studio/grove.p … ove/adc.py”>https://github.com/Seeed-Studio/grove.py/blob/master/grove/adc.py</LINK_TEXT>
-- coding: utf-8 --
This is the ADC library for Grove Base Hat
- Grove Base Hat for RPi <https://www.seeedstudio.com/Grove-WS2813-RGB-LED-Strip-Waterproof-60-LED-m-1m-p-3126.html>_
- Grove Base Hat for RPi Zero <https://www.seeedstudio.com/Grove-Base-Hat-for-Raspberry-Pi-Zero-p-3187.html>_
Grove Base Hat incorparates a micro controller STM32F030F4.
Raspberry Pi does not have ADC unit, so we use an external chip
to transmit analog data to raspberry pi.
Examples:
import time
adc = ADC()
while True:
# Read channel 0(Slot A0) voltage
print(adc.read_voltage(0))
time.sleep(1)
import sys
import grove.i2c
all = [
“ADC”,
“RPI_HAT_NAME”, “RPI_ZERO_HAT_NAME”,
“RPI_HAT_PID”, “RPI_ZERO_HAT_PID”
RPI_HAT_PID = 0x0004
RPI_ZERO_HAT_PID = 0x0005
RPI_HAT_NAME = ‘Grove Base Hat RPi’
“”" The HAT name to compare with return value of :class:ADC.name “”"
RPI_ZERO_HAT_NAME= ‘Grove Base Hat RPi Zero’
class ADC(object):
Class ADC for the ADC unit on Grove Base Hat for RPi.
Args:
address(int): optional, i2c address of the ADC unit, default 0x04
def init(self, address = 0x04):
self.address = address
self.bus = grove.i2c.Bus()
def read_raw(self, channel):
    Read the raw data of ADC unit, with 12 bits resolution.
    Args:
        channel (int): 0 - 7, specify the channel to read
    Returns:
        (int): the adc result, in [0 - 4095]
    addr = 0x10 + channel
    return self.read_register(addr)
# read input voltage (mV)
def read_voltage(self, channel):
    Read the voltage data of ADC unit.
    Args:
    Returns:
        (int): the voltage result, in mV
    addr = 0x20 + channel
# input voltage / output voltage (%)
def read(self, channel):
    Read the ratio between channel input voltage and power voltage (most time it's 3.3V).
    Args:
    Returns:
        (int): the ratio, in 0.1%
    addr = 0x30 + channel
@property
def name(self):
    Get the Hat name.
    Returns:
        (string): could be :class:`RPI_HAT_NAME` or :class:`RPI_ZERO_HAT_NAME`
    id = self.read_register(0x0)
    if id == RPI_HAT_PID:
        return RPI_HAT_NAME
    elif id == RPI_ZERO_HAT_PID:
        return RPI_ZERO_HAT_NAME
@property
def version(self):
    Get the Hat firmware version.
    Returns:
        (int): firmware version
    return self.read_register(0x3)
# read 16 bits register
def read_register(self, n):
    Read the ADC Core (through I2C) registers
    Grove Base Hat for RPI I2C Registers
        - 0x00 ~ 0x01:
        - 0x10 ~ 0x17: ADC raw data
        - 0x20 ~ 0x27: input voltage
        - 0x29: output voltage (Grove power supply voltage)
        - 0x30 ~ 0x37: input voltage / output voltage
    Args:
        n(int): register address.
    Returns:
        (int) : 16-bit register value.
    try:
        self.bus.write_byte(self.address, n)
        return self.bus.read_word_data(self.address, n)
    except IOError:
        print("Check whether I2C enabled and   {}  or  {}  inserted".format \
                (RPI_HAT_NAME, RPI_ZERO_HAT_NAME))
        sys.exit(2)
        return 0
if name == ‘main’:
import time
adc = ADC()
while True:
    time.sleep(1)<e>[/code]</e></CODE>
If anyone has any idea how i can get rid of it i would really appreciate the help. Thankyou!
  1. please comment out helper/helper.py as below.
    pi@raspberrypi:~/grove.py/grove $ vim helper/helper.py
[code] def init(self, slot = GPIO):
adc = ADC()
self.name = adc.name
#print(“Hat Name = ‘{}’”.format(self.name))
self.plat = self.get_platform()
    if self.name == RPI_ZERO_HAT_NAME:
        self.__hat_type = RPI_ZERO_HAT_PID
        self.__slots_gpio = _SlotsGPIORpiZero
        self.__slots_adc  = _SlotsADCRpiZero
        self.__slots_pwm  = _SlotsPWMRpiZero
    else:
#if self.name != RPI_HAT_NAME:
#print(“Unknown hat, assume {}”.format(RPI_HAT_NAME))
self.__hat_type = RPI_HAT_PID
[/code]
  1. run the sudo pip install . --upgrade to update the library. thanks.
</s>pi@raspberrypi:~/grove.py/grove $ cd .. pi@raspberrypi:~/grove.py $ [b]sudo pip install . --upgrade[/b] Processing /home/pi/grove.py Requirement already up-to-date: RPi.GPIO in /usr/lib/python2.7/dist-packages (from grove.py==0.6) Requirement already up-to-date: rpi_ws281x in /usr/local/lib/python2.7/dist-packages (from grove.py==0.6) Requirement already up-to-date: smbus2 in /usr/local/lib/python2.7/dist-packages (from grove.py==0.6) Installing collected packages: grove.py Found existing installation: grove.py 0.6 Uninstalling grove.py-0.6: Successfully uninstalled grove.py-0.6 Running setup.py install for grove.py ... done Successfully installed grove.py-0.6<e>
