Grove BLE dual model and devices
I bought a Grove BLE (dual model) and I would like to detect a device bluetooth. I connected the Grove BLE dual model to an Arduino and tried the sketch which is proposed but I can’t use properly AT command it seems… Please could you help me ?
If you use the example code and there is no problem with your hardware, it couldn’t strike.
Could you pls provide more detailed information?
Thank you for answering,
I tried the example code but it is to link 2 arduino. And I can’t use AT command after the program started. I would like to connect the Grove BLE to a device to receive informations, not sending. I can rename the device, I found its MAC adress Bluetooth, but I can’t use AT+CON+adress. It doesn’t seem to work. What do I have to change ? Here the example code.
[code]/*
Bluetooth HM13 Demo Code
2014 Copyright © Seeed Technology Inc. All right reserved.
Author: Jacky Zhang
This demo code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
For more details about the product please check http://www.seeedstudio.com/depot/
/* Upload this sketch into Arduino Uno and press reset*/
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 2
#define TxD 3
#define MASTER 1 //change this macro to define the Bluetooth as Master or not
SoftwareSerial blueToothSerial(RxD,TxD);//the software serial port
char recv_str[100];
Serial.begin(115200); //Serial port for debugging
pinMode(RxD, INPUT); //UART pin for Bluetooth
pinMode(TxD, OUTPUT); //UART pin for Bluetooth
Serial.println("\r\nPower on!!");
if(setupBlueToothConnection() != 0) while(1); //initialize Bluetooth
//this block is waiting for connection was established.
while(1)
if(recvMsg(1000) == 0)
if(strcmp((char *)recv_str, (char *)“OK+CONB”) == 0)
Serial.println(“connected\r\n”);
break;
delay(200);
#if MASTER //central role
//in master mode, the bluetooth send message periodically.
delay(400);
Serial.println(“send: hi”);
blueToothSerial.print(“hi”);
delay(100);
//get any message to print
Serial.print(“recv: “);
Serial.print((char *)recv_str);
Serial.println(””);
#else //peripheral role
delay(200);
//the slave role only send message when received one.
Serial.println(””);
Serial.println(“send: hello”);
blueToothSerial.print(“hello”);//return back message
#endif
//used for compare two string, return 0 if one equals to each other
int strcmp(char *a, char *b)
unsigned int ptr = 0;
while(a[ptr] != ‘\0’)
if(a[ptr] != b[ptr]) return -1;
ptr++;
return 0;
//configure the Bluetooth through AT commands
int setupBlueToothConnection()
#if MASTER
Serial.println(“this is MASTER\r\n”);
#else
Serial.println(“this is SLAVE\r\n”);
#endif
Serial.print("Setting up Bluetooth link\r\n");
delay(3500);//wait for module restart
//send command to module in different baud rate
while(1)
    delay(500);
    blueToothSerial.begin(9600);
    delay(500);
    Serial.print("try 9600\r\n");
    if(sendBlueToothCommand("AT") == 0)
        break;
    delay(500);
    blueToothSerial.begin(115200);
    delay(500);
    Serial.print("try 115200\r\n");
        break;
//we have to set the baud rate to 9600, since the soft serial is not stable at 115200
sendBlueToothCommand("AT+RENEW");//restore factory configurations
sendBlueToothCommand("AT+BAUD2");//reset the module's baud rate
sendBlueToothCommand("AT+AUTH1");//enable authentication
sendBlueToothCommand("AT+RESET");//restart module to take effect
blueToothSerial.begin(9600);//reset the Arduino's baud rate
//configure parameters of the module
sendBlueToothCommand("AT+VERS?");//get firmware version
sendBlueToothCommand("AT+ADDE?");//get EDR MAC
sendBlueToothCommand("AT+ADDB?");//get BLE MAC
sendBlueToothCommand("AT+NAMEHM-13-EDR");//set EDR name
sendBlueToothCommand("AT+NAMBHM-13-BLE");//set BLE name
sendBlueToothCommand("AT+PINE123451");//set EDR password
sendBlueToothCommand("AT+PINB123451");//set BLE password
sendBlueToothCommand("AT+SCAN0");//set module visible
sendBlueToothCommand("AT+NOTI1");//enable connect notifications
//sendBlueToothCommand("AT+NOTP1");//enable address notifications
sendBlueToothCommand("AT+PIO01");//enable key function
#if MASTER
sendBlueToothCommand("AT+ROLB1");//set to master mode
#else
sendBlueToothCommand("AT+ROLB0");//set to slave mode
#endif
if(sendBlueToothCommand("AT") != 0) return -1;//detect if the module exists
Serial.print("Setup complete\r\n\r\n");
return 0;
//send command to Bluetooth and return if there is a response
int sendBlueToothCommand(char command[])
Serial.print(“send: “);
Serial.print(command);
Serial.println(””);
blueToothSerial.print(command);
delay(200);
if(recvMsg(200) != 0) return -1;
Serial.print("recv: ");
Serial.print(recv_str);
Serial.println("");
return 0;
//receive message from Bluetooth with time out
int recvMsg(unsigned int timeout)
//wait for feedback
unsigned int time = 0;
unsigned char num;
unsigned char i;
//waiting for the first character with time out
i = 0;
while(1)
    delay(50);
    if(blueToothSerial.available())
        recv_str[i] = char(blueToothSerial.read());
        i++;
        break;
    time++;
    if(time > (timeout / 50)) return -1;
//read other characters from uart buffer to string
while(blueToothSerial.available() && (i < 100))
    i++;
recv_str[i] = '\0';
return 0;
[/code]
I kept it configured as MASTER. The other device doesn’t have any password. Do I need to put a password to the Grove BLE ?
Where should I add AT+CON ? Or I need to write something other ?
I think that I can erase part sending “hi”, as the device doesn’t receive any signal.
By the way, when switch on, with this program, it connects to another Bluetooth but it’s impossible to know which one.
