Seeeduino Stalker + Grove sensor PIR
Moderators: lily.li, violet, salmanfarisvp, jeremy882, crail.lyu969
jemwe
Post by jemwe » Sat Apr 07, 2012 9:19 am
hi, I'm trying a seeeduino stalker and a sensor pir, when I calibrate the sensor pir with arduino duemilanove this work ok, but the problem is when I try with seeeduino stalker doesn't work correctly. Will this problem of voltage in sensor pir?
User avatar
deray
Elementary-3
Elementary-3
Re: Seeeduino Stalker + Grove sensor PIR
Post by deray » Mon Apr 09, 2012 2:56 pm
Hi~
Is that arduino duemilanove and Seeeduino Stalker have the same chip"AtMega328p"? And the same working voltage of your sensor PIR and Seeeduino Stalker ?
best regards.
deray
jemwe
Post by jemwe » Sun Apr 15, 2012 1:58 am
The arduino duemilanove have atmega328 and the stalker atmega328p, the difference is the "picopower". Sensor PIR, work with 3v and 5v.
