Regarding Xadow.getChrgState()
Moderators: lily.li, salmanfarisvp, violet
mayfair
Post by mayfair » Sun Aug 17, 2014 8:28 am
I have a question regarding Xadow.getChrgState().
In xadow.cpp, xadow::getChrgState() is implemented as follows.
Code: Select all
unsigned char xadow::getChrgState()
    unsigned char Temp = CHRGpin & CHRGbit;
    if(!Temp)
        return NOCHARGE;
    Temp = DONEpin & DONEbit;
    if(!Temp)
        return CHARGDONE;
    return NOCHARGE;
But if I understand correctly, that should be as follows. Otherwise, the function never returns CHARGING. Moreover, /CHRG means charging, instead of no charge. Is this correct?
Code: Select all
    if(!Temp)
        return CHARGING;
    if(!Temp)
        return CHARGDONE;
    return NOCHARGE;
I'm sorry if this is a false alarm.
