SIPEED MAIX/K210: Access Multi-Core CPU functions in Arduino?
Is there any information regarding the K210 multi-core feature and Arduino? Is this even supported?
suggestion:
2 Tabs in Arduino IDE
Main Tab: (Core0 code)
[code]#include <entry.h>
const uint8_t led = LED_RED;
Serial.print("Start Core: "); Serial.println(current_coreid());
pinMode(led,OUTPUT);
register_core1(main1 , NULL );
const unsigned long interval = 333;
static uint64_t merker = 0;
static bool ledStatus = false;
if(millis() - merker > interval)
merker+=interval;
ledStatus = !ledStatus;
digitalWrite(led,ledStatus);
}[/code]
Second Tab: (Core1 code) [code] const uint8_t led1 = LED_BLUE;
void setup1()
pinMode(led1,OUTPUT);
void loop1()
const unsigned long interval = 1000;
merker+=interval;
digitalWrite(led1,ledStatus);
int main1(void *parameter)
setup1();
while(1)
loop1();
}[/code]
It is blinking with two led.
Be careful with concurrent access to resources.
Example: the serial outputs of both cores mix
