w600 Module AT command WJOIN fail error -10 in AP or SoftAP process
Hello
My W600 wifi module work fine in STA mode but always fail in AP or SoftAP mode. I tried all the examples of the WM_W60X_SDK_AT Command_V1.0.2.pdf sending AT commands with Uart_send_AT_demo.ino.
Exemple of AT sequence :
write—>AT+RSTF
read—>+OK
write—>AT+WPRT=2 // I tried also with 3
read—>+OK
write—>AT+SSID=“MyTEST”
read—>+OK
write—>AT+KEY=1,0,“12345678”
read—>+OK
write—>AT+ENCRY=1
read—>+OK
write—>AT+APNIP=1,192.168.10.1,255.255.255.0,192.168.10.1,192.168.10.1
read—>+OK
write—>AT+WJOIN
read—>+ERR=-10
Thank you for your help.
WJOIN command is only valid when the module joins the wireless network as STA or create a wireless network as an access point (AP). If the current network mode is adhoc, and no specified SSID network can be detected, the module will automatically create a new network. If it is already networking, then the network connection information will be directly returned.
