BBG WIRELESS + GROVE CAPE
Moderators: violet, seth.welday
andrey.polyakov
Post by andrey.polyakov » Tue Apr 03, 2018 2:43 am
I am struggling with making things work. Particularly, not able to get any readings from this https://www.seeedstudio.com/Grove-Tempe ... p-745.html.
Steps that I took:
- Attached sensor to port marked GPIO_115 which I reference as P9_27. Tried other ports/notations unsuccessfully.
- played with default Linux on board, updated, did not work either
- got latest Linux beaglebone 4.9.82-ti-r102 #1 SMP PREEMPT Thu Feb 22 01:16:12 UTC 2018 armv7l GNU/Linux
I attempted to get readings using these libs: bcm2835 1.55, beaglebone-dht, Adafruit_BBIO
Need help in debugging.
cat /proc/interrupts
CPU0
16: 1504837 INTC 68 Level gp_timer
19: 1 INTC 78 Level wkup_m3_txev
20: 1017410 INTC 12 Level 49000000.edma_ccint
22: 62 INTC 14 Level 49000000.edma_ccerrint
26: 514396 INTC 96 Level 44e07000.gpio
33: 0 44e07000.gpio 6 Edge 48060000.mmc cd
54: 514396 44e07000.gpio 27 Edge wl18xx
59: 0 INTC 98 Level 4804c000.gpio
92: 0 INTC 32 Level 481ac000.gpio
125: 0 INTC 62 Level 481ae000.gpio
158: 136 INTC 72 Level 44e09000.serial
159: 1726 INTC 44 Level 481a6000.serial
160: 2141 INTC 70 Level 44e0b000.i2c
161: 118 INTC 30 Level 4819c000.i2c
162: 25192 INTC 64 Level mmc0
163: 1368 INTC 28 Level mmc1
164: 1654283 INTC 29 Level mmc2
166: 0 INTC 77 Level wkup_m3
172: 0 INTC 75 Level rtc0
173: 0 INTC 76 Level rtc0
174: 0 INTC 109 Level 53100000.sham
176: 0 INTC 111 Level 48310000.rng
177: 109400 INTC 18 Level musb-hdrc.0
178: 69 INTC 19 Level musb-hdrc.1
179: 0 INTC 17 Level 47400000.dma-controller
180: 0 INTC 7 Level tps65217-irq
183: 0 - 2 Edge tps65217_pwr_but
IPI0: 0 CPU wakeup interrupts
IPI1: 0 Timer broadcast interrupts
IPI2: 0 Rescheduling interrupts
IPI3: 0 Function call interrupts
IPI4: 0 CPU stop interrupts
IPI5: 0 IRQ work interrupts
IPI6: 0 completion interrupts
Err: 0
debian@beaglebone:/sys/class/gpio$ ls -l
total 0
-rw-rw---- 1 root gpio 4096 Apr 2 13:10 export
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpio12 -> ../../devices/platform/ocp/44e07000.gpio/gpiochip0/gpio/gpio12
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpio13 -> ../../devices/platform/ocp/44e07000.gpio/gpiochip0/gpio/gpio13
lrwxrwxrwx 1 root root 0 Apr 2 13:09 gpio16 -> ../../devices/platform/ocp/44e07000.gpio/gpiochip0/gpio/gpio16
lrwxrwxrwx 1 root root 0 Apr 2 13:10 gpio51 -> ../../devices/platform/ocp/4804c000.gpio/gpiochip1/gpio/gpio51
lrwxrwxrwx 1 root root 0 Mar 29 20:09 gpio60 -> ../../devices/platform/ocp/4804c000.gpio/gpiochip1/gpio/gpio60
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpiochip0 -> ../../devices/platform/ocp/44e07000.gpio/gpio/gpiochip0
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpiochip32 -> ../../devices/platform/ocp/4804c000.gpio/gpio/gpiochip32
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpiochip64 -> ../../devices/platform/ocp/481ac000.gpio/gpio/gpiochip64
lrwxrwxrwx 1 root gpio 0 Mar 29 20:09 gpiochip96 -> ../../devices/platform/ocp/481ae000.gpio/gpio/gpiochip96
-rw-rw---- 1 root gpio 4096 Mar 29 20:09 unexport
Not able to attach this as a file, dmesg follows:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.82-ti-r102 (root@b2-am57xx-beagle-x15-2gb) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP PREEMPT Thu Feb 22 01:16:12 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: TI AM335x BeagleBone Green Wireless
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] free_area_init_node: node 0, pgdat c14e98c0, node_mem_map df961000
[ 0.000000] Normal zone: 1148 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 15 pages/cpu @df928000 s31884 r8192 d21364 u61440
[ 0.000000] pcpu-alloc: s31884 r8192 d21364 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 439932K/522240K available (12288K kernel code, 1155K rwdata, 4364K rodata, 1024K init, 751K bss, 33156K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1300000 - 0xc1400000 (1024 kB)
.data : 0xc1400000 - 0xc1520cc8 (1156 kB)
.bss : 0xc1522000 - 0xc15ddfb0 ( 752 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000035] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000045] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000922] clocksource_probe: no matching clocksources found
[ 0.001396] Console: colour dummy device 80x30
[ 0.001423] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001429] This ensures that you still see kernel messages. Please
[ 0.001434] update your kernel commandline.
[ 0.001455] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.046621] pid_max: default: 32768 minimum: 301
[ 0.046918] Security Framework initialized
[ 0.046930] Yama: becoming mindful.
[ 0.046987] AppArmor: AppArmor initialized
[ 0.047198] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047209] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048407] CPU: Testing write buffer coherency: ok
[ 0.048478] ftrace: allocating 39681 entries in 117 pages
[ 0.160789] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.160854] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.206643] Brought up 1 CPUs
[ 0.206664] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.206670] CPU: All CPU(s) started in SVC mode.
[ 0.208286] devtmpfs: initialized
[ 0.230998] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.231556] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.231579] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.235367] xor: measuring software checksum speed
[ 0.274660] arm4regs : 1217.000 MB/sec
[ 0.314609] 8regs : 1091.000 MB/sec
[ 0.354609] 32regs : 1088.000 MB/sec
[ 0.394607] neon : 1657.000 MB/sec
[ 0.394614] xor: using function: neon (1657.000 MB/sec)
[ 0.394633] pinctrl core: initialized pinctrl subsystem
[ 0.396196] NET: Registered protocol family 16
[ 0.399982] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.428725] omap_hwmod: debugss: _wait_target_disable failed
[ 0.490651] cpuidle: using governor ladder
[ 0.502635] cpuidle: using governor menu
[ 0.511326] OMAP GPIO hardware version 0.1
[ 0.518360] GPIO line 112 (MCASP0_AXR0) hogged as output/low
[ 0.532238] No ATAGs?
[ 0.532259] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.532553] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.532563] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.642690] raid6: neonx2 gen() 1900 MB/s
[ 0.710639] raid6: neonx2 xor() 1170 MB/s
[ 0.710647] raid6: using algorithm neonx2 gen() 1900 MB/s
[ 0.710652] raid6: .... xor() 1170 MB/s, rmw enabled
[ 0.710658] raid6: using intx1 recovery algorithm
[ 0.720680] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.724862] SCSI subsystem initialized
[ 0.726807] libata version 3.00 loaded.
[ 0.727172] usbcore: registered new interface driver usbfs
[ 0.727245] usbcore: registered new interface driver hub
[ 0.727364] usbcore: registered new device driver usb
[ 0.727959] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.729569] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.729826] media: Linux media interface: v0.10
[ 0.729887] Linux video capture interface: v2.00
[ 0.729985] pps_core: LinuxPPS API ver. 1 registered
[ 0.729992] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.730015] PTP clock support registered
[ 0.730998] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.735015] Advanced Linux Sound Architecture Driver Initialized.
[ 0.735826] NetLabel: Initializing
[ 0.735837] NetLabel: domain hash size = 128
[ 0.735841] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.735942] NetLabel: unlabeled traffic allowed by default
[ 0.739065] clocksource: Switched to clocksource timer1
[ 0.867261] VFS: Disk quotas dquot_6.6.0
[ 0.867382] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.867805] AppArmor: AppArmor Filesystem Enabled
[ 0.882971] NET: Registered protocol family 2
[ 0.884099] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.884146] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.884204] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.884283] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.884304] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.884518] NET: Registered protocol family 1
[ 0.893509] RPC: Registered named UNIX socket transport module.
[ 0.893519] RPC: Registered udp transport module.
[ 0.893524] RPC: Registered tcp transport module.
[ 0.893528] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.893547] PCI: CLS 0 bytes, default 64
[ 0.894216] Unpacking initramfs...
[ 1.091133] random: fast init done
[ 1.351922] Freeing initrd memory: 6360K
[ 1.352490] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 1.355617] audit: initializing netlink subsys (disabled)
[ 1.355713] audit: type=2000 audit(1.284:1): initialized
[ 1.361298] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.361477] zbud: loaded
[ 1.366727] NFS: Registering the id_resolver key type
[ 1.366769] Key type id_resolver registered
[ 1.366775] Key type id_legacy registered
[ 1.366793] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.367291] fuse init (API version 7.26)
[ 1.367738] orangefs_debugfs_init: called with debug mask: :none: :0:
[ 1.368046] orangefs_init: module version upstream loaded
[ 1.368054] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1.388664] Key type asymmetric registered
[ 1.388680] Asymmetric key parser 'x509' registered
[ 1.388817] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.393141] io scheduler noop registered
[ 1.393153] io scheduler deadline registered
[ 1.393255] io scheduler cfq registered (default)
[ 1.394868] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 1.396097] gpio-of-helper ocp:cape-universal: ready
[ 1.398883] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.400627] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.404029] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 1.416922] console [ttyS0] enabled
[ 1.418061] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 159, base_baud = 3000000) is a 8250
[ 1.420526] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.420829] [drm] Initialized
[ 1.422878] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.423403] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.423655] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.423913] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.427367] libphy: Fixed MDIO Bus: probed
[ 1.428415] CAN device driver interface
[ 1.430218] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.430264] ehci-pci: EHCI PCI platform driver
[ 1.430335] ehci-platform: EHCI generic platform driver
[ 1.430524] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.431137] usbcore: registered new interface driver usb-storage
[ 1.433512] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.439436] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.443301] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.443344] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.443702] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.443713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.443721] usb usb1: Product: MUSB HDRC host driver
[ 1.443729] usb usb1: Manufacturer: Linux 4.9.82-ti-r102 musb-hcd
[ 1.443737] usb usb1: SerialNumber: musb-hdrc.1
[ 1.444763] hub 1-0:1.0: USB hub found
[ 1.444825] hub 1-0:1.0: 1 port detected
[ 1.458306] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.460080] i2c /dev entries driver
[ 1.462285] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.463788] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.464764] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.582189] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.585199] mmc0: new high speed SDHC card at address aaaa
[ 1.590419] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.593375] mmcblk0: p1
[ 1.596597] mmc1: new high speed MMC card at address 0001
[ 1.601782] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[ 1.606389] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[ 1.610962] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[ 1.612781] mmcblk1: p1
[ 1.664999] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.665518] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.666892] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.669824] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.671369] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.673562] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.674405] usbcore: registered new interface driver usbhid
[ 1.674413] usbhid: USB HID core driver
[ 1.674899] remoteproc remoteproc0: wkup_m3 is available
[ 1.680064] wireguard: WireGuard 0.0.20180218 loaded. See www.wireguard.com for information.
[ 1.680077] wireguard: Copyright (C) 2015-2018 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 1.680517] NET: Registered protocol family 10
[ 1.685963] mip6: Mobile IPv6
[ 1.685988] NET: Registered protocol family 17
[ 1.686007] can: controller area network core (rev 20120528 abi 9)
[ 1.686082] NET: Registered protocol family 29
[ 1.686211] Key type dns_resolver registered
[ 1.686217] mpls_gso: MPLS GSO support
[ 1.686519] omap_voltage_late_init: Voltage driver support not added
[ 1.693518] mmc2: new high speed SDIO card at address 0001
[ 1.695907] PM: Cannot get wkup_m3_ipc handle
[ 1.700528] ThumbEE CPU extension supported.
[ 1.700557] Registering SWP/SWPB emulation handler
[ 1.701639] registered taskstats version 1
[ 1.701775] zswap: loaded using pool lzo/zbud
[ 1.707878] Btrfs loaded, crc32c=crc32c-generic
[ 1.746869] Key type encrypted registered
[ 1.746895] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.792646] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.793214] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.793691] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.793787] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.795249] remoteproc remoteproc0: powering up wkup_m3
[ 1.795271] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 1.795524] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 1.795542] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 1.801264] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,GW1A,BBGW16055481'
[ 1.801294] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 1.843105] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.847699] bone_capemgr bone_capemgr: Invalid signature 'ffffffff' at slot 0
[ 1.854933] bone_capemgr bone_capemgr: slot #0: No cape found
[ 1.887645] bone_capemgr bone_capemgr: slot #1: No cape found
[ 1.919978] bone_capemgr bone_capemgr: slot #2: No cape found
[ 1.952679] bone_capemgr bone_capemgr: slot #3: No cape found
[ 1.958582] bone_capemgr bone_capemgr: initialized OK.
[ 1.961301] PM: bootloader does not support rtc-only!
[ 1.962351] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.962364] of_cfs_init
[ 1.962501] of_cfs_init: OK
[ 1.963372] PM: Hibernation image not present or could not be loaded.
[ 1.963580] wlan-en-regulator: disabling
[ 1.963599] ALSA device list:
[ 1.963606] No soundcards found.
[ 1.965737] Freeing unused kernel memory: 1024K
[ 1.985535] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 1.985553] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.985561] usb 1-1: Product: USB2.0 Hub
[ 1.986849] hub 1-1:1.0: USB hub found
[ 1.987333] hub 1-1:1.0: 4 ports detected
[ 5.746382] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.396730] systemd[1]: System time before build time, advancing clock.
[ 6.476559] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.528923] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 6.529702] systemd[1]: Detected architecture arm.
[ 6.542116] systemd[1]: Set hostname to <beaglebone>.
[ 7.242596] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.243291] systemd[1]: Reached target Swap.
[ 7.244128] systemd[1]: Listening on Journal Audit Socket.
[ 7.245633] systemd[1]: Created slice User and Session Slice.
[ 7.246664] systemd[1]: Created slice System Slice.
[ 7.246838] systemd[1]: Reached target Slices.
[ 7.248379] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.529177] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro
[ 8.498513] systemd-journald[314]: Received request to flush runtime journal from PID 1
[ 12.619839] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 13.612727] random: crng init done
[ 15.340613] using random self ethernet address
[ 15.340633] using random host ethernet address
[ 15.435003] using random self ethernet address
[ 15.435023] using random host ethernet address
[ 15.630517] Mass Storage Function, version: 2009/09/11
[ 15.630543] LUN: removable file: (no medium)
[ 15.794912] usb0: HOST MAC 88:c2:55:89:1c:d7
[ 15.803361] usb0: MAC 88:c2:55:89:1c:d8
[ 15.811459] usb1: HOST MAC 88:c2:55:89:1c:da
[ 15.813023] usb1: MAC 88:c2:55:89:1c:db
[ 16.085543] configfs-gadget gadget: high-speed config #1: c
[ 16.472781] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 16.666022] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 16.827485] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 25.282156] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 25.410014] remoteproc remoteproc1: 4a334000.pru0 is available
[ 25.410141] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a334000 probed successfully
[ 25.442124] remoteproc remoteproc2: 4a338000.pru1 is available
[ 25.442291] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a338000 probed successfully
[ 28.468624] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 28.625635] wlcore: loaded
[ 29.123795] wlcore: PHY firmware version: Rev 8.2.0.0.236
[ 29.172521] wlcore: firmware booted (Rev 8.9.0.0.69)
[ 29.191303] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.685033] IPv6: ADDRCONF(NETDEV_UP): SoftAp0: link is not ready
[ 31.698135] wlan0: authenticate with 02:18:4a:aa:2e:d0
[ 31.708567] wlan0: send auth to 02:18:4a:aa:2e:d0 (try 1/3)
[ 31.732711] wlan0: authenticated
[ 31.735800] wlan0: associate with 02:18:4a:aa:2e:d0 (try 1/3)
[ 31.737537] wlan0: RX AssocResp from 02:18:4a:aa:2e:d0 (capab=0x1531 status=0 aid=1)
[ 31.792416] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 31.794251] wlan0: associated
[ 32.267173] wlcore: Association completed.
[ 34.080106] wlcore: down
[ 34.238960] IPv6: ADDRCONF(NETDEV_CHANGE): SoftAp0: link becomes ready
[ 36.331512] Bluetooth: Core ver 2.22
[ 36.331709] NET: Registered protocol family 31
[ 36.331717] Bluetooth: HCI device and connection manager initialized
[ 36.331746] Bluetooth: HCI socket layer initialized
[ 36.331777] Bluetooth: L2CAP socket layer initialized
[ 36.331829] Bluetooth: SCO socket layer initialized
[ 36.357768] Bluetooth: HCI UART driver ver 2.3
[ 36.357790] Bluetooth: HCI UART protocol H4 registered
[ 36.357796] Bluetooth: HCI UART protocol BCSP registered
[ 36.357802] Bluetooth: HCI UART protocol LL registered
[ 36.357808] Bluetooth: HCI UART protocol ATH3K registered
[ 36.357813] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 36.358147] Bluetooth: HCI UART protocol Broadcom registered
[ 36.358154] Bluetooth: HCI UART protocol QCA registered
[ 36.855375] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.855393] Bluetooth: BNEP filters: protocol multicast
[ 36.855427] Bluetooth: BNEP socket layer initialized
[ 38.080190] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 02:18:4a:aa:2e:d0
[ 387.137083] configfs-gadget gadget: high-speed config #1: c
[ 387.396583] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 1565.923528] wlcore: Beacon loss detected. roles:0x1
[ 1570.798915] wlcore: Connection loss work (role_id: 0).
[ 1570.798967] wlan0: Connection to AP 02:18:4a:aa:2e:d0 lost
[ 1571.422713] wlcore: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1571.517638] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1572.352842] wlan0: authenticate with 02:18:4a:aa:2e:d0
[ 1572.357822] wlan0: send auth to 02:18:4a:aa:2e:d0 (try 1/3)
[ 1572.658925] wlan0: send auth to 02:18:4a:aa:2e:d0 (try 2/3)
[ 1572.766923] wlan0: send auth to 02:18:4a:aa:2e:d0 (try 3/3)
[ 1572.803142] wlan0: authenticated
[ 1572.810942] wlan0: associate with 02:18:4a:aa:2e:d0 (try 1/3)
[ 1572.881858] wlan0: RX AssocResp from 02:18:4a:aa:2e:d0 (capab=0x1531 status=0 aid=1)
[ 1572.891919] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1572.894169] wlan0: associated
[ 1574.815203] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 02:18:4a:aa:2e:d0
[ 1576.139413] wlcore: Association completed.
[ 3223.714398] wlcore: ERROR command complete timeout
[ 3223.719283] ------------[ cut here ]------------
[ 3223.719579] WARNING: CPU: 0 PID: 6 at drivers/net/wireless/ti/wlcore/main.c:796 wl12xx_queue_recovery_work.part.10+0x68/0x6c [wlcore]
[ 3223.719586] Modules linked in: cmac bnep hci_uart btbcm btqca bluetooth xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 ccm arc4 wl18xx wlcore mac80211 cfg80211 rfkill pruss_soc_bus wlcore_sdio evdev uio_pdrv_genirq uio usb_f_mass_storage usb_f_acm u_serial usb_f_ecm usb_f_rndis u_ether libcomposite iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_filter spidev pru_rproc pruss_intc pruss tieqep ip_tables x_tables
[ 3223.719753] CPU: 0 PID: 6 Comm: kworker/u2:0 Not tainted 4.9.82-ti-r102 #1
[ 3223.719759] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 3223.720339] Workqueue: phy0 ieee80211_iface_work [mac80211]
[ 3223.720390] [<c0114468>] (unwind_backtrace) from [<c010dd20>] (show_stack+0x20/0x24)
[ 3223.720417] [<c010dd20>] (show_stack) from [<c07451e0>] (dump_stack+0x80/0x94)
[ 3223.720434] [<c07451e0>] (dump_stack) from [<c013e358>] (__warn+0xf8/0x110)
[ 3223.720447] [<c013e358>] (__warn) from [<c013e488>] (warn_slowpath_null+0x30/0x38)
[ 3223.720619] [<c013e488>] (warn_slowpath_null) from [<bf2c0f28>] (wl12xx_queue_recovery_work.part.10+0x68/0x6c [wlcore])
[ 3223.720851] [<bf2c0f28>] (wl12xx_queue_recovery_work.part.10 [wlcore]) from [<bf2c47cc>] (wl12xx_queue_recovery_work+0x24/0x28 [wlcore])
[ 3223.721028] [<bf2c47cc>] (wl12xx_queue_recovery_work [wlcore]) from [<bf2c6cfc>] (wlcore_cmd_send_failsafe+0x90/0x4d8 [wlcore])
[ 3223.721201] [<bf2c6cfc>] (wlcore_cmd_send_failsafe [wlcore]) from [<bf2c88c0>] (wlcore_cmd_configure_failsafe+0x6c/0xf4 [wlcore])
[ 3223.721374] [<bf2c88c0>] (wlcore_cmd_configure_failsafe [wlcore]) from [<bf2c896c>] (wl1271_cmd_configure+0x24/0x30 [wlcore])
[ 3223.721545] [<bf2c896c>] (wl1271_cmd_configure [wlcore]) from [<bf2cfff8>] (wl1271_acx_slot+0x80/0xd4 [wlcore])
[ 3223.721715] [<bf2cfff8>] (wl1271_acx_slot [wlcore]) from [<bf2bf3f8>] (wl1271_bss_erp_info_changed+0x4c/0xec [wlcore])
[ 3223.721885] [<bf2bf3f8>] (wl1271_bss_erp_info_changed [wlcore]) from [<bf2c1e18>] (wl1271_op_bss_info_changed+0x4b0/0xeb4 [wlcore])
[ 3223.722256] [<bf2c1e18>] (wl1271_op_bss_info_changed [wlcore]) from [<bf1e7080>] (ieee80211_bss_info_change_notify+0xd8/0x2cc [mac80211])
[ 3223.722624] [<bf1e7080>] (ieee80211_bss_info_change_notify [mac80211]) from [<bf23ea18>] (ieee80211_rx_mgmt_beacon+0x9e0/0x1374 [mac80211])
[ 3223.722935] [<bf23ea18>] (ieee80211_rx_mgmt_beacon [mac80211]) from [<bf2406b0>] (ieee80211_sta_rx_queued_mgmt+0x31c/0x9a8 [mac80211])
[ 3223.723239] [<bf2406b0>] (ieee80211_sta_rx_queued_mgmt [mac80211]) from [<bf1fe46c>] (ieee80211_iface_work+0x2c4/0x418 [mac80211])
[ 3223.723403] [<bf1fe46c>] (ieee80211_iface_work [mac80211]) from [<c015b78c>] (process_one_work+0x18c/0x4e8)
[ 3223.723418] [<c015b78c>] (process_one_work) from [<c015c5fc>] (worker_thread+0x60/0x53c)
[ 3223.723435] [<c015c5fc>] (worker_thread) from [<c0161f34>] (kthread+0x118/0x130)
[ 3223.723456] [<c0161f34>] (kthread) from [<c0109050>] (ret_from_fork+0x14/0x24)
[ 3223.730149] ---[ end trace 2c15808bc0165077 ]---
[ 3223.730227] wlcore: WARNING CONFIGURE command NOK
[ 3223.730236] wlcore: WARNING failed to set slot time: -110
[ 3223.730244] wlcore: WARNING Set slot time failed -110
[ 3223.730383] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.69
[ 3223.730988] wlcore: pc: 0x1134, hint_sts: 0x00000200 count: 1
[ 3223.731468] wlcore: down
[ 3223.731530] wlcore: down
[ 3223.731542] wlcore: down
[ 3223.732713] ieee80211 phy0: Hardware restart was requested
[ 3224.185009] wlcore: PHY firmware version: Rev 8.2.0.0.236
[ 3224.230557] wlcore: firmware booted (Rev 8.9.0.0.69)
[ 3224.263762] wlcore: Association completed.
jellyfish
Re: BBG WIRELESS + GROVE CAPE
Post by jellyfish » Wed Apr 04, 2018 6:24 pm
I tested the temperature and humidity sensor with your firmware and it doesn't work. Then I changed to a previous firmware and it worked. This is the download link for the old firmware:
http://debian.beagleboard.org/images/bo ... 4gb.img.xz
I hope this will work.
Best Regards
Jelly
Seeed Techsupport Team
silver1row
Contact:
Post by silver1row » Fri Apr 20, 2018 6:36 pm
Did you try to use config-pin on your terminal while plugged in? You may need to adjust your "already-default" configured pins.
Seth
P.S. So, if I wanted to set up PWM on "P9_14," I would type, sudo config-pin P9.14 pwm. I would then hit the enter/return button afterwards. To check to see what pins are configured and how they are configured, use the -q argument. So, to check for "P9_14," you would type sudo config-pin -q P9.14 and then hit enter/return.
