Easy programming for the DSO Quad
--DSO203
Moderators: violet, jessie, jpa
c.wilt
Re: Easy programming for the DSO Quad
Post by c.wilt » Sun Jan 06, 2013 2:32 pm
Today I got an error when loading pawn.
redscreen hardfault
SP:2000bcf0 PC:080442ac LR:08045063
SCB HFSR:40000000 CFSR:00008200 BFAR:74ab4c00
There are also R0 to R12 listings as well as Callers.
I have tried reloading older versions of everything and it still does it. I also loaded jpa's flashtst.hex into app4 to see if it might have a problem in that slot but it worked fine. When I loaded pawn again it still does the hardfault.
Any help would be appreciated.
My gut tells me its because I loaded the logo file. I have not found a way to erase and start clean.
jpa
Elementary-2
Elementary-2
Post by jpa » Sun Jan 06, 2013 5:28 pm
c.wilt wrote: SP:2000bcf0 PC:080442ac LR:08045063
That PC address is in the AlterBIOS memory. Try reloading AlterBIOS.
(I'm not sure if I should combine the alterbios image to Pawn image, so that they are both in the same .HEX file)
c.wilt
Post by c.wilt » Mon Jan 07, 2013 12:38 am
That was it. Not sure what happened but its working again.
I was making headway on calibration last night. Trying to add supply voltage differences. Is it possible to get CPU temp in pawn?
jpa
Elementary-2
Elementary-2
Post by jpa » Mon Jan 07, 2013 12:48 am
c.wilt wrote:That was it. Not sure what happened but its working again.
Nope, and even if it was the CPU temp sensor requires calibration itself also.
c.wilt
Post by c.wilt » Mon Jan 07, 2013 1:46 am
I don't care if its accurate. Monitoring drift over time could help.
jpa
Elementary-2
Elementary-2
Post by jpa » Mon Jan 07, 2013 1:59 am
c.wilt wrote:I don't care if its accurate. Monitoring drift over time could help.
True; but it would only be a second-hand estimate for the ADC / analog stage temperature. Because the data is all digital from the ADC onwards.
c.wilt
Post by c.wilt » Mon Jan 07, 2013 9:07 am
Let me back up and explain why I was asking about monitoring temp drift over time. I noticed drift when using the DSO with standard or alternative firmware when measuring RMS. This is about the same time I lost access to pawn. There is several volts drift after minutes.
I just checked the volt meter readout with pawn and it is rock steady. I also checked the Vref on the ADC.
Now I assume there is a bug in the RMS calculations.
jpa
Elementary-2
Elementary-2
Post by jpa » Sun Feb 17, 2013 4:16 pm
There is new release 0.08 that fixes a bug with FFT causing hardfaults.
http://koti.kapsi.fi/~jpa/dsoquad/#QuadPawn
fdufnews
Kindergarten
Kindergarten
Post by fdufnews » Sun Feb 17, 2013 7:12 pm
Thank you for the update.
Note that the application still identify itself as V0.07 in the about window
MartinKaiser
Post by MartinKaiser » Mon Jun 24, 2013 5:01 pm
Hi!
Little hint: always download the Zip from github etc .. everytime i load an .hex, .bin or .amx file Firefox & Chrome corrupted them !
Downloaded everything as .zip an now everything works like charm !
thanks for this great piece of software !
Greets Martin
