SenseCAP M1 Adjust Antenna Gain
Would it be possible to have a setting to adjust the antenna power?
I moved my antenna outside and now I’m getting ~30% invalids due to the signal being too high. With a setting you could use a higher gain antenna and “dial” it down to optimize for your location and the current POC rules.
This can already be done in the Helium app. Open the gear settings for your hotspot in the Helium app and select update hotspot. You will need to select the antenna and the gain (height is not required). If your antenna is not listed then select custom antenna and put in the correct information. There is a small fee ($.55) to do this and once done it should stop giving you invalids. Good luck
