I purchased Grove - Micro Switch and am using for a project that just requires the C and NO
The groove switches have gnd, vcc, nc, D1. Which connection what I use just to have the C and NO?
To use the Grove - Micro Switch with just the common (C) and normally open (NO) connections, you’ll typically connect the following:
This Types of drama configuration ensures that the common (C) terminal is always connected to the normally open (NO) terminal when the switch is in its default state. When the switch is activated (pressed or toggled), the circuit between “C” and “NO” is closed, allowing current to flow through your input/output device.
